- Apr 11, 2006
Hi, I have a Gustard U12, and this past weekend tried bypassing the relay with a wire soldered between the legs. It worked in that the Gustard powered up without 5 volt power with the bypass installed. Unfortunately, it wouldn't play without 5 volt power.
My solution was to install an Aqvox USB connector which takes 5 volt power from an external source as substitute for the dirty power from the host computer. One leg of a Keces power supply supplies the 5v power.
It sounds great!
FYI, Aqvox will sell the cable without the linear power supply, if like me, you have one already.
This is very strange, it looks like the U12 does indeed need the 5V USB supply, and to be honest, that worries me a little bit,,,
