rb2013
Author of The 6922 Tube Review
- Apr 12, 2013
"yes, I've tried with a cable without 5v and it doesn't work. Someone took the transformer and ac parts out and said it no longer needed the 5v from usb cable. think it operates the relay, so if the relay isn't there then maybe that's why. Someone also said xmos chip requires 5v to switch on, not sure about that or whether the usb 5v would be the supply for this."
Ok, thank you for confirming! I was wondering because when connecting U12 to USB source, it immediately switches on, even if its connected to 5V USB power adapter.
Thats a pitty because we can't make a decent cable without power, so polluted 5V from pc will still influence USB signal in cable (interference).
Now i really have to buy the Elfidelity USB card for proper clean usb 5V signal
+1 a report on that on Elfidelity USB card and the U12 in terms of compatiblity and SQ would be great
