I hope all you guys are happy for making me very late for work today
the new gustard x20 looks to offer 'more' of the x12 goodness... i'm kinda in the same boat atm, re i2s dac.
wow, where have I been. That's the first I heard of the X20
I also tried the USB regen and didn't see any improvement to be outright honest. Maybe my system is already ideally setup. I'm using very good cables and powering everything from pure sinewave from a ps audio ps300 a/c regenerator w/multiwave2 (big improvement).
Check out audio-gd and you'll be surprised how much you get for you're money. Don't be fooled by the poor english translations. The quality of the product is insanely good and well built. They have a 10year warranty too.
I'm using all the IFI stuff (minus the tube buffer) for usb regen, and I'm plenty happy. I also use a PS3 for A/C regen, though I found I could listen longer with multiwave off. Still it's always a pleasure to do "regression testing" after any serious change to the audio chain.
With you on the R2R thing.
Wynnytsky you could also checkout the Master 7.1 uses the R2R PCM1704 - 8 of them and has the hdmi input you're looking for. $2295 plus shipping.
I've always thought that Kingwa would continue to improve his 9018 implementations until they bested his vintage chips, but now it's my time to give R2R a try. This year I've heard the magic of a passive TVC (transformer volume control, but in my case it was Dave Slagle's autoformer). If I get the Master 7 this winter then I'll use it with an integrated tube amp and maybe next year I'll get a passive pre for my main rig. But perhaps the preamp section of the Master 11 is something to be desired?
What puzzles me is that the Master 11 claims to be a Master 7 + 9
Master 7: 15kg $2225
Master 9: 16kg $1550
Master 11: 15kg $1950
And yet, the weights and prices don't reflect that
Also when I compare the input power and DAC output impedance...
Master 7: 48watt, 10ohm
Master 11: 45watt, 1ohm
...it's strange that the unit with the preamp consumes less power.
And wouldn't the lower output impedance be more attractive?
I plan to never put cans on my head.
Which way to go: RB's M7 or Bimmer's M11?
(I believe the "7.1" designation applies to the Reference model, which is actually cheaper than the master)
