Gustarender 1v43 is just a name presented on the network. In fact, each device may have a different operating system. Just as the A26 has a different partitioning method, the same may be true for the AH90. It is not possible to download firmware for the AH90, so I cannot compare. In my opinion it probably won't work.Will this work on the AH90 too?
It’s still the Gustarender1v43.
Looks like they have a “s” version out now too.
GUSTARD DAC-R26 Balanced Decoder R2R+1Bit Dual Native Decoding Music Bridge
- Thread starter m-i-c-k-e-y
holzohr
- Sep 9, 2013
Change log of the "s" version:
04.02.2024
Fixed the mac address
M43T7N
@wikaudio would you mind sharing with us the ssh password? Or how you managed to find that out? I'm trying to access my AH90's firmware to change network settings and the password could be the same.That's true, since firmware 1.43 they added random MAC. I didn't even notice it, but I connected via SSH and managed to turn it off. I will try to share the corrected firmware without random MAC tomorrow.
M43T7N
link?
but keep in mind this is for the AH90 not the R26S version 1v43 download link:
https://www.mediafire.com/file/gp8bqk4lgisz2x1/AH90_gustarender_1v43s_package_only_AH90.zip/file
I don't know the password, but I do it by inserting SSH key to R26. I found a description of how to do it HERE@wikaudio would you mind sharing with us the ssh password? Or how you managed to find that out? I'm trying to access my AH90's firmware to change network settings and the password could be the same.
m-i-c-k-e-y
Thanks anyway. I thought its a non public FW for the R26. Because I searched and could not find one.but keep in mind this is for the AH90 not the R26
Any dates for a version with DSD on UPnP (I'm using Roon with MUSE to convert CD quality files to DSD)?As promised, I am providing a link to the improved 1v43 firmware.
R26_1v43_no_random_MAC.zip
This is the original firmware in which I disabled random MAC. If someone uses Roon, after uploading to R26 you need to re-enable R26 in Roon Audio
To the question: why did they enable random MAC? I don't understand it at all. Normally this is used for security on public Wi-Fi, but these are devices operating on home networks, so...
When it comes to using Tidal connect on Android, the problem is with certificates. What Gustard shared in firmware 1v43 is the same as what I shared earlier. They didn't come up with anything new because they would have to pay for a certificate, so they used what can be found on GitHub. That's why it doesn't work very well.
Thank you. All working corectly.As promised, I am providing a link to the improved 1v43 firmware.
I was challenged by @Keysee to improve Tidal Connect on Android devices. I put in some time and finally I can say, I DID IT!
I tested on a tablet with Android 10.0 and a phone with the latest TIDAL Music: HiFi, Playlists 2.107.0 APK and it works without any problems.
Below is the link to the firmware.
R26_Gustarender_1v43_Tidal.MAC_fix.zip
As before, this is the original 1v43 firmware containing my 2 fixes: restoring a static MAC address and the ability to control the R26 with Tidal Connect on Android devices.
I hope it works for you too.
jsiets4
Question. I use Spotify connect to get it to the R26. Is there any advantage to using Tidal connect as opposed to Roon? Opinions?I was challenged by @Keysee to improve Tidal Connect on Android devices. I put in some time and finally I can say, I DID IT!
Spotify and Tidal are streaming services. Spotify offers the worst quality, Tidal offers HiRes files but is very criticized for MQA. Roon, on the other hand, is a local file server and supports streaming services such as Tidal, Quobuz, Kkbox and Dropbox. Of course, in addition to the Roon license, you also need separate licenses for streaming services.Question. I use Spotify connect to get it to the R26. Is there any advantage to using Tidal connect as opposed to Roon? Opinions?
Therefore, your question should be about the comparison between Spotify and Tidal.
Roon is most often used by people who have a lot of HiRes files and also use streaming. However, the price of Roon + streaming is often not acceptable to everyone. Instead, you get an excellent server with one application that works perfectly with many devices.
Any chance to do this for the A26/Ah90 as well?I was challenged by @Keysee to improve Tidal Connect on Android devices. I put in some time and finally I can say, I DID IT!
I know a lot of guys would be very grateful.
jsiets4
Thanks for your reply I guess my question should have been worded better. I already have Roon ( I built a Roon ROCK ) and a Tidal subscription. I just wondered if there was any advantages to using Tidal connect as opposed to Roon that I was not aware of. I use spotify to listen to the NY Times amplifier playlist that comes out twice a week and occasionally for other things but I mostly listen to Tidal and my own music collection thru Roon.Spotify and Tidal are streaming services. Spotify offers the worst quality, Tidal offers HiRes files but is very criticized for MQA. Roon, on the other hand, is a local file server and supports streaming services such as Tidal, Quobuz, Kkbox and Dropbox. Of course, in addition to the Roon license, you also need separate licenses for streaming services.
Total: 14 (members: 0, guests: 14)
