eyalcat
- Nov 18, 2010
First I'm not a bass-head, the bass is just missing & the mids are too forward (if I identify it right).
I had a pair of SR80i that are not known for their full bass as well, and comparing to them, there's no bass at all in my V5's.
Thanks
I wouldn't think so. Mine are in wood cups from Martin as well.(though they are much lighter than my SR325is) These aren't bass-heavy in the best of circumstances. I would definitely try another amp, but that may not be the problem. It may just be the clean, detailed, flat signature is not ideal for what you listen to. Also, on your computer (if its windows) try going to the Control Panel, Sound, then click properties for your DAC/output device. See if you have a bass boost option on the Enhancements tab. I found a slight bump at 50hz was a nice touch for some music. I normal avoid all "enhancements", but this one is just a simply eq adjustment.
Thanks
