Solarium
- Oct 19, 2013
I'm starting to think more and more that the amp in the m9XX isn't adequate for anything higher than 300 ohms. It was fine with the HD700 and HD800, but when I use the T1 it sounded like it needs more power even at 75 volume. Even compared to my Asus STX II sound card, which uses a more inferior DAC, the m9XX when using the T1 feels less engaging and feels more lifeless. The HD800 definitely sounded better on the m9XX than then STX II, but likely due to it being 300 ohms. I can't pinpoint the exact difference of the STX II and m9XX, but the the magic with STX II and T1 was lost when I moved to the m9XX, it sounds less liquid, the bass isn't as impactful, and the highs are not as exciting. It feels as though more controlled and there is more of a cutoff at the highest trebles and lowest of bass. Hard to explain but kind of disappointing.
