Hello. Does anyone notice sound quality difference between Mojo and M9xx?
I am keen to purchase either of them now and not sure which one to go for.
I read reviews on both products and they are all great.... I do not have any hard to drive headphone so amp power is not top priority but sound quality is.
I am currently using Meridian Explorer as main dac/amp at the moment.
It is good to have an option of portability but I mainly listen with MBA so portability is less concern and main focus is sound quality.
I was told that M9xx compare nicely with Mojo in terms of sound quality and dac performance but not sure if there is any noticeable difference between the two in terms of Dac/Amp performance.
Any feedback would be greatly appreciated. Thank you.
I have owned both and kept the m9XX.
Both are excellent (and certainly beat the Explorer) - you are likely to be very happy with either.
The Mojo will cope a little better with harder to drive headphones if that became a future requirement. As you say, the Mojo is also better for portable use.
The m9XX is much more easy to use in a desktop scenario however and so, if that is your priority, I would recommend the m9XX over the Mojo.
