WilliamLeonhart
They do sound similar. I'd say, just from my experience, the m9XX is a bit less detailed at the top end and has a wider soundstage. Whereas the Mojo is a bit more accurate across the board and has a slightly more closed-in soundstage. As with most things in this field, you have to make a personal determination between "fun" and "technical" and what's right for you. Also, the cans you hope to pair them with.
The big differentiator is feature-set and form factor. Leaving the m9XX on all the time and having it connected to phones and speakers simultaneously is a lot easier than with the Mojo. I can leave most things plugged into the Grace. The Mojo is a lot more portable and isn't really meant to anchor a desktop solution.
Sounds the same as what I'd say about the M9xx vs the iDSD Micro. I'm very happy with both.
