kothganesh
- Dec 30, 2012
haha something that they announce to make you feel better but deep inside the ETA is Xmas ( hits you back to reality )
Exactly...we don't have it yet...
Comparing the number of components between components is meaningless, especially if one uses primarily SMD parts and one uses full-size parts. Also, the Pulse board doesn't include the PSU, which is separate.
I couldn't agree more, and was surprised that anyone thought there was some correlation between the number of components on the board and the quality of the circuit. If anything, its the opposite of what was being said, the fewer parts needed to make a circuit perform at a high level, the better.
Certainly in high-end circles, simpler is always viewed as better, because each and every part on the board has it's own inherent noise/distortion characteristics, the more you add the more there is. There's also an additive effect with heat, and thus distortion, nearly every part will contribute to this. The fewer parts you have, the better the layout can be and more room between parts generally means less thermally induced distortion.
And last but not least, as @Currawong noted, there is no PSU in the main Pulse chassis, it is external. So apples to oranges as compared to the layouts of many other circuits that are using the main chassis to also house the PSU, the Pulse design is superior in that respect too, external PSU is almost always markedly better sounding for a variety of reasons.
I for one hope we keep seeing pictures of sparsely populated Pulse boards (std; S, and X) that show a whole lot of empty real estate, all the better for sound quality.
What's C/P factor?
Update 9/16/2014: We're getting close to the beginning of Geek Pulse deliveries! All we're waiting on now is the OLED screens. As you know, we'll be getting a batch of those on the 28th of this month.
Larry has been busy taking measurements of Geek Pulse to ensure that the boards we're getting in from the assembly house are passing muster. He's published those measurements here. Please have a look!
Hi, Everyone
Here is the first complete testing report of production version of Geek Pulse. (with Femto and Amp upgrade option on)
Pretty amazing.
Testing environment and condition: Audio Precision APX-525. Calibrated in 10-July-2014. with Bandwidth options to measure up to 1M Hz.
Condition: Line-out: Load 100K, Bandwidth up to 90K Hz. (important, usually people only measure to 20K Hz)
Headphone: Load 300 Ohm, Bandwidth up to 90K Hz.
Testing Units: Geek Pulse with FI option and pair with Geek LPS 110V/60 Hz. (We didn't use switching power here)
Line Out Level: 2.25V. Chanel balance is perfect.
THD+N is pretty amazing....
Signal to Noise Ratio...
Frequency Response (-3dB by Analog filter set near 50K Hz. 2nd Bessel Filter. )
Cross Talk --- Left and Right are almost complete separated (Test @ 1K Hz, -0dBFs)
Let's see the Headphone results.
Normal Gain Setting: Output = 3V rms.
SNR
THD... Still amazing.
Static Noise level...
A little bit more deeper....
Harmonic Distortion Ratio: One of the most important thing I love to "see" how does this unit sound...
FFT... Of course, another important chart for Geeky people. No 60Hz/120/240 noise there, completely. Noise Floor is at -150dB or lower.
The other one I like to check: IMD. SMPTE ratio, testing under 60Hz and 7K herz, ratio at 4:1.
Jitter performance... Actually, something we could see from the "skirt" around 1K center frequency. Reminding: This is the femto clock performance.
And let me attached one more FFT from the TXCO... Skirt is a little bit wider, and have two minor spikes. But still nice.
Enjoy!
We will know by Friday...
Also, ESS people are quite amazing for our Geek Pulse's result too. Because our test results are from real life...
Nice figures Larry!
I wonder if the X and S variations will achiveve the 127db SNR advertised in the ESS product page (www.esstech.com/PDF/ES9018-2M%20PB%20Rev%200.8%20130619.pdf) ... It would show a clear advantage of the balanced/differential design over the Pulse, even with the femto and op-amp upgrades... Although 118db is very very good for the single ended version
Noise floor, distortion and crosstalk values (the ones I understand the best) are very impressive...
The structure almost complete cancel out 2nd harmonic due to "full balance" structure. So when sum up at the output stage, it cancel out the 2nd harmonics.
The more important thing is: You could see a sky clear HD above 5th. No high order distortion is a must for great sound. (Quote from John Curl or Pass or?) And I also found this truth about 12 years ago.
Knob is temporary and not final
