Originally Posted by ClieOS /img/forum/go_quote.gif
Generally speaking, foam tips have a warmer, bassier, but less detail sound than silicone / PVC. Deeply inserted silicone eartips will have a bassier, slight more detail sound than shallowly inserted tips.
Thanks Skyla...ClieOS, nice guide!
I'm not so sure about the part I quoted though...at least as far as my ER4-P/S's are concerned. I don't like the foam tips at all, and I seem to have more bass with the white tips. Also, I think the further they are inserted, the less bass I get, after a certain point. I get a good seal on them, and more air in the ear canal, properly sealed, the better bass due to my ear acting more as a "bass drum". Too far in, and the bass thins. Improper seal, no bass at all. I used to have a problem seating them and sealing them properly without putting them in too far, but I have a "fitting system", if you will. I follow Ety's instructions:
*For best results, moisten the white soft plastic eartips before insertion.
*Using your right hand, grasp the eartip with the red plug.
*With your left hand, pull up and back on your right ear to straighten your ear canal.
*Carefully insert the right earphone so that it seals deeply and comfortably in your ear.
*Repeat procedure for the left ear, using the earphone with the blue plug.
*Remove earphones slowly with a twisting motion to gradually break the seal.
My variations on this are that prior to inserting them, I open my jaw fully a few times to clear any air in my ears, and pop them if they need it. Then, when inserting them, I start with the cable end up, and insert while turning them 180 degrees, so that when they are seated, the cable is pointing down (in the proper "hanging cable" angle). I also found that I can seat them at the proper depth by clenching my jaw tightly when inserting them. This prevents me from inserting them too far, and avoiding the feeling of them sitting on my jaw joint. You can really tell if they are in too far by opening your mouth widely after inserting, as a final test...if you can feel it in any way on your jaw, back them out just a bit.
Hope this helps, if anyone has issues with inserting IEMs properly...try it yourself, and see what you think.
