BMF mentioned before in the big post there , Michael's Craft Store carries some rolls of fabric tape.
I was there and saw the Aileen's (?) version,
but in a different section a few aisles over I found this stuff ( in the wool-sort-of section ) it is the same stuff, seems to be the manufacturer for Aileen's I bet, and it is cheaper ( about half price here ).
http://canada.michaels.com/on/demandware.store/Sites-MichaelsCanada-Site/default/Product-Show?pid=C_gc3000
looks like it comes in sheets also
I would HIGHLY recommend this, even if only at the 4 corner points of the pad edges. No more awkward precarious feeling of the pads falling off, these are ON.
That feeling bothered me all the time. When wearing them I just always knew in my mind they were looser than they should have been.
I personally seal up the baffle to cup seam so don't worry about sealing with the tape pieces themselves. The stuff is tremendously sticky and will stick to your fingers and scissors, so don't use good scissors.
It's so durable it is machine washable even, but unlike other double sided tape sheets I have used in the past from art supply places this doesn't seem like heat will affect is as much. It even says on the back: "Tumble Dry Low Heat"
Also recommend small pieces of this for securing internal mod bits down so nothing shifts when reseating the cups. One less variable to worry about, and as I mentioned it will
not get sloppy with heat and weep into any stuff like driver backing materials etc.
Thanks for making me go look for the stuff BMF
