mikey1964
- Dec 20, 2014
LOL , will go ahead with the purchase....
I've asked before, but I'll ask again before I throw something together here. Anyone have any ideas for baffle design for this setup? I think I'm going to go ahead and use mdf so it's easier to shape, and maybe be best to rid it of vibration. I also need to figure out a way yo attach the pads, easiest way would be tape them to the cups for now. I just have this aching feeling the baffle design will be key here in making this particular setup work. Hell I'd be willing to do some driver mods as well if someone has solid suggestions.
Interesting tid bit...
When to the source tried ALL the headphones heh.... they were looking at me funny, but they know me.
Tried some momentums. Strangely good. Anyways I thought they were rather bass heavy, I looked up some graphs, yes they are bass heavy, but really not that much in the least. The other cans I tried sounded similar. (Other then actual bass heavy cans) so turns out my t50rps are bass light...... hmm it seems to be the normal 4mm thick Sliverstone foam. My cup vents are open too. Too much foam?
I would try closing the vents a little. Maybe half way.
To increase bass?
I think that much foam would kill the bass, since the only thing it is doing it reducing the volume of the cups since it's not a porous material the bass doesn't travel through it.
You're probably better off starting with something like cotton balls if bass quantity is the goal.
Combine that WITH the suggested vent mod and you're on your way to getting the 'best' of both quantity and quality.
