I'm not going to look up any tech specs or do any reading of other reviews to skew my impressions.
- microphonic cord unless the neck cinch is pulled up and tightly curved over the ear
- impressive packaging
- superb case... all metal and sturdy, I could probably run a car over it, except it's actually kinda heavy
neat little case for the filters
- Utterly inconsequential nitpick: if the filter case has an o-ring seal, why not the large case which arguably would find that more useful.
- seems high efficiency, picks up a lot of noise from my NuPrime uDSD
- probably very low impedance
- I'm not a fan of these super high efficiency low impedance headphones for precisely the noise reasons;
- angle/fit isn't quite right for my ears; slightly on the large side for me
- isolation just average
Not gonna talk about all the possible combinations that you can play with; just some thoughts in brief. First of all, do not assume that those filters only change their range in isolation to the others, especially between the bass/ultralow ports. Seems to affect overall sensitivity as well.
The mid/high filters:
- I can't see anyone ever using the blue (least highs) unless you have particularly bad sensitivities up there
- gold is a bit honky
- black is more neutral but kinda peaky compared to green
- green feels a bit shelved, higher but flatter than blue? more ethereal
Bass ports:
- this is where most punch comes from
- add more at the cost of flubberiness
- I mostly just left it on grey (medium)
- the black (most) was all thump without kick and seemed to actually take away from the ultralows
Ultra low ports:
- very little actual primary content exists in this area, so just adjust rumble to taste
- I felt red (most) started to blur the edges of the bass notes above
- but high bass ports diminished the ultralows, so it's a balancing act
Overall
- most notable upper end: shimmery and snaps but does not fatigue quickly (remove with blue filter if needed)
- soundstage a bit behind and below me
- Overall evaluation is tricky since mucking with frequency response changes perception so much.
If I had to guesstimate the price, based on sound quality and all the accessories, I would think $400 (roughly 300+100 in my head)
Trying to get a sense of the drivers and housing, the FLC8 feels like a very competent IEM. Clarity is excellent. Not the absolute best, but pretty darned good.
For this price bracket
do I feel the price is worth $350?
I think as a tweaker's delight it certainly fits
for those of us that like to “set and forget” as it were, I feel it's just slightly on the upper end of the spectrum but not unreasonable
