shotgunshane
- Sep 25, 2010
If you do hear some treble peak - I suppose you are on some silicone tips, right? All silicone tips no matter what type or size do elevate the higher mids and highs with unwanted reflections (like small cave in your ear). This will never happen with the foam tips, as they do absorb all reflections in a same way as the (foam) acoustic treatment in the recording studios.
This applies to all universal in-ears. - that's why is there such a confusion especially on the JH Layla/Angie thread. Customs are way different sounding than universals, because everyone is changing the gazillion types of tips back and forth
I used both silicone and foam. Agree on foam absorbing treble reflections and ringing issues as a general rule. But my issue wasn't with reflections or ringing but more of a tonal issue. I just didn't like the tone this peak causes the overal treble to take on and this tonality was a problem regardless of tip type.
I'm sure canal shapes play a role in this as well. Anyway, I'm just another data point on the overall map.
