I don't know if it would be useful to a lot of people, but 2 headphones output would be very appreciated by me.
I like to share the music
The C&C amps have this function for instance.
Oh, come on...just :
Are there any prototype/early production Fiio X7's circulating with trialists at the moment?
That'll double the amp section, which will be quite a lot to ask consider FiiO's amp section tends to be more complex than most.
It is true that it might add components but I m not sure we would need to double the complete amp section.
Doubling only the current amplification stage might be enough, wouldn't it be ?
Have they finalized what DAC chip they are going with and if it's going to be double or not?
------------------------------------------updated on 3st, May, 2014-----------------------------------------------------------------------------------------------------------------------------------------
Here we have some decision about our new flagship portable DAP as below.
Model NO. X7
ETA: 2015
M.S.R.P: $699 in U.S
OS: Custom OS based on Android, can supports some third party APP from our website.
Weight: Less than 300g
Size: thickness will be almost the same as X5 , the other size is almost the same as 5 inch Android Phone.
Screen: 3.5 inch ~ 4.3 inch Full Touch Screen. To be decided.
Key layout: Full touch control+ Bottoms+ Volume Knobs
Output power: > 300mW/32 ohms, Power supply: +/- 6V ~ +/-11 V . To be Decided.
Playtime: 10 hours
Battery: Build in Battery.
Data transfer: USB 2.0 ( Micro USB), WiFi
Blue Tooth: YES , supports APTX
DAC chip: ESS9018 , not ESS9018M2K, The ES9018 includes 8 channels DAC which means it is equal to 4 X ESS9018M2K
Enclosure: Metal
Build in memory: To be decided.
Extra Memory: Micro SD slot X 2
Accessory : Leather Case X 1, Micro USB cable X 1,
Dear James,
My dream player is a X5 with an empty mSATA slot (so that I can add my own 1TB mSATA SSD for $530, 500GB for $300 or 250GB for $170). Or X5 with 4 (four) microSD (TF) slots.
I am sure you have seen the poll result (wish list) for X7's features. Ability to support large storage was the second most wanted feature from over 100 Headfi votes. Maybe you can set up another vote and ask how much storage people would "dream" of. In my humble opinion, if you have lots of (high resolution) music, 256 GB is a must, 512GB is nice, 1024GB is a "dream". One of the selling point of X5/X3/X1 is high resolution playback, correct?
MicroSD / TF cards are still too expensive for too little storage. With that said, if you equip X7 with
4 microSD slots, I will happily fill them all with 128GB cards now. ~500GB of microSD will cost me over $480 now, while ~500GB of mSATA SSD costs only $300 currently.
mSATA SSDs are getting even bigger and cheaper because they are commonly used in tablets/laptops. Currently a 480GB (Crucial/Micron) mSATA SSD can run for 8-13 hours in a Rockboxed iPod Video 5.5th generation with 850 mAh battery, so it does NOT need a huge battery or a super thick enclosure:
http://www.head-fi.org/t/566780/official-ipod-video-classic-5g-5-5g-6g-6-5g-7g-ssd-mod-thread/2610#post_10410434
http://www.head-fi.org/t/566780/official-ipod-video-classic-5g-5-5g-6g-6-5g-7g-ssd-mod-thread/2670#post_10430207
