Bytor123
- Apr 6, 2013
Do you know if the SD card that they are offering in a bundle on Amazon is definitely compatible with the X1!?
Thanks for that; I'd read about some cards not being recognised
Originally Posted by Lamsa /img/forum/go_quote.gif
I too am deciding between the X1 and X3. I would love to get a more detailed comparison of their sound quality. As for features, what would I be missing out on if I got the X1?
Thanks in advance!
I have both. After work or staying at home, the "better" sound of the X3 is more obvious than if I were using either when I move around. Having had the X3 a good few months before I received my X1, I did not exactly "felt" it was a downgrade in sound quality. To my-not-golden-ears, the X3 is "warmer" while the X1 has more liveliness, like strings sound more "there." There is obviously a difference.
For headphones my typical on-the-go is an HD-239. The X1 is just as enjoyable with my Grado and HD518. I recently tried to experience IEMs. So, now, I have a Fidue A63 and Soundmagic's E30. I prefer the E30 on both the X1 and X3. But for quiet and critical listening, the A63 sounds "better." I use my HD600 for nigh time quiet-and-just-listen sessions with the X3-as-DAC + O2. So, the DAC option to me is a big plus in favor of the X3.
Yet, the line-out of the X1 to my E11K or the JDS Labs O2 or the E09K is just as enjoyable. On the go, I use the E11K with my X1 more to extend the battery life.
So, X1 or X3? If I had to choose for a "just a portable" DAP, the X1+E11K is a good combo. Can the X3's DAC sway you to it? That's for you to try and find out
Probably a good point. I just hope the X1 is indeed a noticeable step-up from the rockboxed Clip+ I currently use. Do you happen to have seen any reliable reviews of the X1 with classical music?
