[FiiO KA5]FiiO Portable DAC and Headphone Amplifier, Multifunctional local OS | OLED display | Dual CS43198 DACs | PCM 768kHz/32bit | DSD256 | 3.5+4.4 dual outputs | App connectivity
Oct 4, 2023 at 7:14 AM Post #436 of 536
Is there any info on approximately release date of KA7?
Oct 4, 2023 at 7:29 AM Post #437 of 536
deleted
Oct 5, 2023 at 12:43 PM Post #441 of 536
And the last one,
Headphone gain for 3.5mm output is 2Vrms(High) & 1.4Vrms(Low), is this numbers right?
Thanks
Oct 5, 2023 at 1:56 PM Post #442 of 536
Dear friend,
Please try whether the attachment works?
Best regards
Now it works! This new Fiio KA5 audio driver is able to go up to 1024 samples buffer size in my DAW, Pro Tools.
Thank you so much! I'm so happy and grateful you did it!
God bless you!
Fiio team are so cool!
Nov 14, 2023 at 7:15 AM Post #444 of 536
Im getting clicks when listening after ~5 minutes. When I listen to not loud and classic music (Piano or cello) sometimes I hear clicks from the left. It's random audible clicks usually 5~10 times per song. I have already changed the cable, tried different settings, and still, there are clicks. Kinda annoying. Does anyone have a similar problem?
I was getting this as well. I swapped out the supplied USB C to USB C cable with a flat rubberized one that I found on Amazon for £11. Problem fixed, so my bee some poor cables go through QC. I guess Fiio do not make the cables, just source them from a 3rd party. Great DAC, I'm more than happy with it driving my 150 Ohms RHA CL750 IEMs
Nov 18, 2023 at 1:52 AM Post #445 of 536
@FiiO Kang
Do any of KA1, KA2, KA3, KA5, KA13 support in-line microphone (4-pole 3.5mm CTIA TRRS)?
Nov 25, 2023 at 7:50 AM Post #448 of 536
I ordered two dongles today.
1) Fiio KA5
And
2) Fosi Audio DS1
My first foray into dongles. I kept my LG V30 going for about five and a half years, but I finally had to upgrade.
No 3.5mm jacks anywhere.
So, a great value DAC/amp and one of the market leaders. Should be fun!
How did it compare to your V30? I have one and a V50 thinq which I've been using last couple of years with UAPP and the PEQ driving mostly Dunu EST iems and occasionally LCD-X. I've been hugely impressed with the V50 given its just a phone, my desktop setup is a JDS element 2 / Roon. Sadly the v50 needed replacing, so now looking for an external dongle to connect to an S23 Ultra. From experience, it's less about the DAC and much more about the amp, I note that the KA5 is rated at 150mW or thereabouts, but I've no idea what the specs are for the V50 to compare. I have no doubt they'll drive the Dunus without a problem, but not so sure about the audeze, not that it's that important as they're not exactly designed to be portable.
Nov 25, 2023 at 11:07 AM Post #449 of 536
I do miss my V30. At least for the simplicity. The dongle works great, but is a pain to haul around. Luckily 95% of my listening is desktop.
It will not be powering my HE6se V2's, but all my other 'phones work just fine.
Nov 25, 2023 at 2:18 PM Post #450 of 536
I just got this. the 4.4 output cuts out at higher volume, 3.5 does not. I updated to the latest firmware but its still cutting out at higher volume. anyone know why?
Using through a iphone 13 pro max.
