I used the cable that was supplied.
[FiiO KA5]FiiO Portable DAC and Headphone Amplifier, Multifunctional local OS | OLED display | Dual CS43198 DACs | PCM 768kHz/32bit | DSD256 | 3.5+4.4 dual outputs | App connectivity
- Thread starter FiiO
White Hat Bob
I have an iPhone SE(2020) and the KA5 works flawlessly. Perhaps the KA5 is in UAC1.0 mode for gaming. From FiiO "With the KA5 not connected to any device and off, press and hold the multifunction key. While holding the key, connect the KA5 to your desired device to enable UAC1.0 mode." iPhones require UAC2.0 for music. Try a "Factory Reset" Also check the status of "SPDIF OUT," which should be "Off," and Hardware Mute Switch also should be Off. Remember, the volume controls on the iPhone and KA5 are completely independent. If either is set to zero, there will be no sound. Good luck!I just received my KA5 to take with me on a trip. I can’t seem to get it working with my iPhone SE(2020) or iPhone 12. Works flawlessly on my MacBook though. Am I doing something wrong?
Thanks for the elaborate reply. I have reset the device, checked the settings while connected to my laptop and then connected it to the phone again to no avail. Connecting it to my laptop immediately makes the screen light up, nothing when connecting to my phone...
White Hat Bob
The fact that nothing is happening on the KA5 display when you plug in the KA5 is NOT how mine works. The display comes on for 5 sec (default, make sure yours is not set to display timeout to "0" but this should have been covered by the reset) whenever you plug the KA5 in. So I'm thinking either 1) it's the cable or 2) the iPhone is blocking the USB connection through security settings. 1) Even though you said you're using the FiiO cable that came with it, it may be damaged/defective (Since MacBooks don't have a lightning connector, I assume you're not using the same cable for the Mac and iPhone). iPhones are notoriously picky about cables for music devices. Mine worked out of the box with the FiiO cable, but I wanted a longer cable, so I purchased several longer ones before I found one that worked, so I learned that many usb/lightning cables are charging only, and that often is not clear in the description... and 2) there is a setting on the iPhone SE under "Touch ID & Passcode" that "Allow Access When Locked", set "Accessories" to "ON." If that's already On, try "Off" (it all depends on Lock status and state).Thanks for the elaborate reply. I have reset the device, checked the settings while connected to my laptop and then connected it to the phone again to no avail. Connecting it to my laptop immediately makes the screen light up, nothing when connecting to my phone...
Dear friend,I just received my KA5 to take with me on a trip. I can’t seem to get it working with my iPhone SE(2020) or iPhone 12. Works flawlessly on my MacBook though. Am I doing something wrong?
Sorry to hear about that. Does the sound come from your iPhone at that time? Please try to restart the iPhone to see whether the issue remain?
And if you have another OTG cable, please have a check. Thanks in advance!
Best regards
Instead of playing through the KA5, it'll play music from the phone speakers. I have checked the "Accessory" settings in the iPhone, I have also completely reset one of the phones to check if there have been some settings that might have been blocking the KA5. To me it seems like it's the cable that's defective. It's a shame, because I can't get it replaced before my trip so I'll have to send the device back. Thanks for the help!
Dear friend,Instead of playing through the KA5, it'll play music from the phone speakers. I have checked the "Accessory" settings in the iPhone, I have also completely reset one of the phones to check if there have been some settings that might have been blocking the KA5. To me it seems like it's the cable that's defective. It's a shame, because I can't get it replaced before my trip so I'll have to send the device back. Thanks for the help!
Thanks for the kind feedback. We apologize for any inconvenience in the meantime!
Best regards
Here is my comparison review of the INCREDIBLE Fiio KA5. A delight for the Detail and clarity seekers without much fatigue.
I have told that fiio ka5 support in line microphone. Anyone using it can confirm please?
Dear friend,I have told that fiio ka5 support in line microphone. Anyone using it can confirm please?
The KA5 does not support in line microphone. The KA1 supports instead.
Best regards
Women who like music are more beautiful
vitaliy88tkachenko
Hello Dear Fiio! I have Fiio KA5 and I'm using it with my DAW (Pro Tools) However, The H/W Buffer size is limited to 256 samples maximum, while all my other devices operate up to 1024 samples buffer size with my DAW. Could you please kindly add the option to work at 1024 sample buffer size to Fiio KA5 Asio Audio Driver? Thank you! |
Dear friend,
Hello Dear Fiio!
Thank you!
We will report to the engineer for checking about that first.
Best regards
Excuse me, have you installed the driver for KA5?
Hello Dear Fiio!
Thank you!
