[FiiO KA5]FiiO Portable DAC and Headphone Amplifier, Multifunctional local OS | OLED display | Dual CS43198 DACs | PCM 768kHz/32bit | DSD256 | 3.5+4.4 dual outputs | App connectivity
Sep 25, 2023 at 11:26 AM Post #421 of 536
Excuse me, have you installed the driver for KA5?
Yes, sir! I have installed the driver for KA5 (FiiO USB Audio Driver), and it works with my Daw (Pro Tools).
But unfortunately it doesn't allow me to use buffer size higher than 256 samples. while all my other interfaces can use 512 and 1024 samples buffer size. That's significant for me, so could you please add that support to FiiO USB Audio Driver?
Sep 27, 2023 at 8:04 AM Post #422 of 536
Can you help me try other software to see if it works? For example, FB2000.
Sep 28, 2023 at 8:39 PM Post #428 of 536
Does anyone know if the KA5 uses both DAC's for the 3.5mm port? I know the BTR5 used only one of the dual dacs through the single ended port. I assume the BTR7 and KA5 both only use one DAC for 3.5mm but can't find much info on that.
Oct 3, 2023 at 7:27 AM Post #429 of 536
Hi guys, I have a questions does KA5 remembers gain setting, and other settings too? (when disconnected from a device and reconnected)?
Thanks
Oct 3, 2023 at 10:00 AM Post #431 of 536
And one more thing, does it works with Iphone and apple music app in exclusive mode, so no volume control on iphone, only on a dac?
Oct 3, 2023 at 1:19 PM Post #432 of 536
Thanks
Yes it remembers settings
I don't know
Oct 4, 2023 at 4:19 AM Post #433 of 536
  • FIIO USB Audio driver 20230928.zip
Oct 4, 2023 at 4:28 AM Post #434 of 536
Dear friend,
The volume buttons in iPhone could adjust the volume at that time as well.
Best regards
Oct 4, 2023 at 4:31 AM Post #435 of 536
Dear friend,
KA5 uses dual DAC chips when using 4.4mm output and 3.5mm output.
Best regards
