DCY77
- Mar 24, 2014
only a very soft power on pop. helps if you turn it on gently
That I'm aware of. This was constant popping with static that wasn't stopping.
Yes, there is noise with no audio playing but we won't notice it while playing songs. Also noticed there is noise when I bring my fingers near the volume knob or input jack. May be the metal body is causing it.
I have this problem with the E10 which is all metal cased like the E11k is I think. Touch the metal case near the volume control and you get this crackling. It is very bad at times when turning the volume dial on my E10. This is why I sometimes prefer these things to not be in an all metal casing like my old E11 which has never had ths isssue.
Hmm, never noticed this. What type of phones/IEMs are you using?
I'm wondering if the higher impedance of my cans might be rendering this noise unnoticeable.
Will this DAC reduce hissing on some sensitive headphones?
Bought this amp yesterday. I have awful EMI problem with it. Using it with a phone is basically impossible if the phone is not in airplane mode. Anybody else experiencing similar problems?
PS. I agree, it needs bass boost level 2 switch
