DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Feb 24, 2017 at 6:52 AM Post #4,621 of 22,021
Be interesting what you think of DX200 with 1Plus2.2, see how close our impressions mirror one another.
I think you're using a different cable than me though but those are the breaks.
Don't forget to run your DX200 in, 2000 200 hours.
200 hrs seems to be the magical number eh? Actually with the 1Plus2.2, I have the stock cable as it's 2.5mm. I'm guessing you're thinking I have the Brise but that's a 4.4mm for the WM1Z.
Feb 24, 2017 at 7:01 AM Post #4,622 of 22,021
I stopped counting at 37 but don't tell anyone...
 (can only count to 50 max)
Sure, I have a stock balanced cable here though run 3.5mm single ended (stock).
Looking forward to your thoughts.
Feb 24, 2017 at 7:35 AM Post #4,624 of 22,021
  If I'm not mistaken someone made a post in the thread about his successfull experience of getting the DX200 to work as a USB digital transport for an external DAC using the Hiby or another third-party player software. I wonder if USB Audio Player also does the job on DX 200...
So I need to use apps to support it. The mango player in android or pure mode doesn't support USB Digital Audio Out Mode?
Feb 24, 2017 at 8:13 AM Post #4,625 of 22,021
The Mango player supports USB output to an external DAC without the need for a 3rd party app.
I just tried it using pure Mango via USB out to my Shozy Magic DAC/Amp and also to my Hilby external USB DAC and both worked perfectly after rebooting.
Feb 24, 2017 at 9:18 AM Post #4,626 of 22,021
Cool! Thanks for the info, I thought this feature was not implemented in the current firmware
Feb 24, 2017 at 11:28 AM Post #4,627 of 22,021
I just brought a otg usb-c adapter and try but it didn't work on pure Mango or Android mango mode. I tried hiby app it detect my DAC but lots of static sound.
Feb 24, 2017 at 12:19 PM Post #4,629 of 22,021
Feb 24, 2017 at 1:16 PM Post #4,632 of 22,021
Strange as both my external DACs worked fine. I have not tried any apps with it yet as I didn't need them. I found it is necessary to reboot once they are attached. I am also running the latest firmware.
Feb 24, 2017 at 3:52 PM Post #4,635 of 22,021
  I wonder if each new amp module will need the same extensive burn in
IMO all amp etc, need burn in. I have found that I heard changes on the DX200 even up to 500 hours. It becomes more and more refined sounding and subtle music cues become more evident as the background seems to become backers and micro detail increases. A smoothness comes about without loosing dynamics and detail. I am not comparing to the WM1Z as the 1Z burns in but IMO the DX200 is better than the WM1A, and even though I have said it a few times, I repeat it because with all the resources that Sony has, I felt the 1A could have been better. To me, the 1Z is a step up from the 1A and more in line with the DX200.
