Has it been confirmed that the DX200 can work flawlessly with the Tidal app ?
DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
- Thread starter Paul - iBasso
- Tags
- at8ie ibasso ibasso dx200
TjPhysicist
Ooh i wanna know about offline. Actually I wanna see the UI too (i.e. is it a full and complete android with home screen etc or a stripped down version like in AK).
Mimouille
It is a full version.Ooh i wanna know about offline. Actually I wanna see the UI too (i.e. is it a full and complete android with home screen etc or a stripped down version like in AK).
Have you tried any streaming apps, i assume you don't use Tidal?
Mimouille
I don't stream at all on DAPs and haven't tried.
kenz
- Feb 24, 2013
Can check out the pics mimouille posted,
http://www.head-fi.org/t/791531/dx200-details-of-design-features-and-specifications-on-1st-page-updated-12-17-2016/2010#post_13143032
Mimouille
These pics only include the ibasso software. There is also a normal android part.Can check out the pics mimouille posted,
TjPhysicist
That's not too bad..maybe. As long as it doesn't make me feel like I'm carrying around a cheap fatter version of my android phone in the other pocket.
H20Fidelity
- Feb 11, 2012
Streaming tests will actually be interesting. I believe this is where the early released FiiO X7 ran into issues with unwanted Wifi noise.
- Nov 26, 2013
Streaming tests will actually be interesting. I believe this is where the early released X7 ran into issues with unwanted Wifi noise.
I don't think it was only the early ones... If I understand it right they still have those issues.
H20Fidelity
- Feb 11, 2012
Thanks. I said early because I only read about it back then. Wasn't sure if the issue was ever resolved.
- Nov 26, 2013
NP, I had two that exhibited the issue (one less than the other but still), a few months later I asked if it was resolved and a forum member said it still hadn't . It might be fixed now though.
H20Fidelity
- Feb 11, 2012
I think Spotify or Tidal have trial periods, maybe Mimouille can try. Or at least turn on DX200 Wifi and create some acitivy with music playing.
its quite important feature...
tin427
- Sep 8, 2013
Though installing the apps is a bit time consuming, but it works flawlessly.
No noise are detected by my balanced K10.
H20Fidelity
- Feb 11, 2012
If this holds true for all units, amp modules and single ended output we will have many happy times ahead!
(thank you for installing it etc)
For what's worth I don't stream, but I know MANY consumers will be.
Total: 18 (members: 0, guests: 18)
