WCDchee
- Oct 5, 2013
Though installing the apps is a bit time consuming, but it works flawlessly.
No noise are detected by my balanced K10.
more impressions and comparisons?
If this holds true for all units, amp modules and single ended output we will have many happy times ahead!
(thank you for installing it etc)
For what's worth I don't stream, but I know MANY consumers will be.
by "control of bass" you mean it has less bass?Comparing to my DX90 and mojo, I think the most impressing are the sound stage and the details.
Everything from mojo seems like have good separation, but in a very room like a studio.
The sound sig of DX200 is like DX90, but with better control of bass, clearer mid and better high frequency extension.
Though the firmware are still a bit laggy(especially using the Mango), but ibasso will continue to update it till perfect.
I am also curious how lurker can help to mod the firmware (I have been using Lurker firmware for DX90 till now:wink_face: ).
Could I trouble you to try the mojo fed from the dx200?I have found the mojo to really scale with certain sources. How does the dx200 fair in terms of resolution and transparency to that pairing of the dx200 and the mojo?sorry for the trouble and thanks loads!
First iBasso should publish full flash firmware...I am also curious how lurker can help to mod the firmware
The updated firmware isnt full?
It is an OTA file, as far as I understand. It is a zip archive that contains only modified parts. Full flash is an update.img file, which contains all the firmware parts.
No noise when streaming that is good news. I own X7 and it has a lot of noise detected using noble katana when streaming or downloading. My level of interest just up 3 level
so with sensitive iems like zeus and wifi and bluetooth on there is no hiss or noise
