Massdrop has the DN2k right now?
Just the DN2000 "J" right now but they offer the DN2000 and DN1000 as drops fairly often. There's usually a spot where you can request a new drop.
Hope that helped...
Cheers!
-HK sends
I would say 2000J meets that particular line between critical and fun factor. I can listen to an Ane Brun track concreting on her vocals, the depth, detail in her voice. (which has very good weight btw) in the mids. Or, I can play some electronic music, still be saturated in detail and taken into the song. This is just from casual listening.
It was probably me who you read recommending the T1 amp with DN-1000.
While I haven't heard the pairing for a long time I would advise the 2000J upgrade over the amp.
2000J is higher performing than the T1 / DN-1000, especially in richness, detail and layering.
How do you like them with your Pono? My 2000J has shipped...now the wait.
Well, its a tough one because we bring in that always questioned output impedance issue. Ideally, you want under 1ohm output impedance for DN-2000J. Pono having output impedance measured by Tyll of 3.27ohms isn't very convenient.
But what the hell, let's plug them in anyway...
It sounds fractionally bright in tone, quite detailed but lacking some refinement. Little shakey around the mid-range, for example, holding dignity of female vocals. Pono definitely pushed through much of its signature and you gain that effortless, natural cross digital tone. Vocal sibilance is also present but I'm finding this across a few sources with FiiO X1 being the best behaved. Great clarity and detail though, just sounds a little uncontrolled in the mid-range.
But there's no glaring hollowness or sucked out sections usually present with OI mismatching.
Treble is quite well behaved.
You should like it, but just make note of the slighly lacking refinment.
What DAC/amp has the recommended impedance of 1ohm for these? Not looking like my e17 will be appropriate for these
I'm still learning...
So deciding between this DN2000J and the Aurisonics ASG-2.5. Hmm....which one should I get... so hard to decide. I know the ASG-2.5 has more bass but other than that I don't know.
^ I'm getting the R2A, which is supposedly not too far off (relatively speaking) to the R2Pro. I plan to compare it to the DN-2000J when I have both.
You will be fine with E17. Very nice, low output impedance.
http://www.head-fi.org/t/587912/fiio-e17-alpen-first-impression-final-thought/195#post_8051178
Guys, the output impedance of your source isn't a complete deal breaker in most cases. Ideally under 1ohm is preferred for the 8ohm 2000J, but it's not a 100% concrete. I would suggest trying with your own sources before running out buying a new one.
In many scenario they will sound fine.
