You are pretty talented to do such a good job with those connectors. My people are working with 615 4 pin mini xlrs of them as we speak.
Do the Grados stay on your ears well, I always wondered about cups that can swivel that much. Do you have to adjust them a lot?
Thanks, I had not seen a pair up close so your insight helps.
I cannot tell by the photo if there are removable cables to each cup and if not then the 4 pin mini xlr system does provide a lot of versatility. You can make pig tails most any length required.
thanks i just take my time and think things out
they stay on your head pretty good t gives you a lot of adjustment
you can use metal collars to lock them down
they're made for rc plane landing gear i think they can be had for a few bucks
I kind of thought they might have some kind of locking system but you certainly fashioned one for yourself, very nice.
I have to think things through on a daily basis and use wire and connectors I can trust or we could be in big trouble. When you get into things like cabling for warning systems on any passenger aircraft that might hold more than 30 people you best take it seriously.
Those connectors will last well and they are easy to plug and unplug. I need to build more for myself when I get the time one day.
It makes no difference whatsoever on color. You have my address by PM.
I am just doing a down and dirty star quad to the mono 2.5's and 3.5 TRS on the other end. I ask the person to choose colors and they say yes. They will be happy with what they get lol.
I messed up applying 4:1 adhesive-lined heat shrink. Any tip on removing it? Make a cut and heat it up? Or is it going to be too messy and I best leave it there even if it's not to my taste?
I figured out now that I should heat up the side I want to keep in place first...
ok, but if you get in that situation again, it is not as bad as it seems to remove. Some heat and side cutters can do the job. I also like to keep small sheers around that look like scissors but they are made for tougher work.
They are not something I would use in a production situation day in and day out but for an occasional build they would hold up fairly well. Years ago i would buy some of the $20 heat guns off of Ebay and they would last a few months and start spitting out sparks. Better ones are made by Steinel in the $60 to $150 range but those are more for high usage.
This one is my all time favorite, whisper quiet and you can change the heating element for different temperatures.
This the one I use. It's very reliable and only $26
https://smile.amazon.com/Wagner-0503008-HT1000-200-watt-Heat/dp/B00004TUCV
Wagner 0503008 HT1000 1,200-watt Heat Gun
