ChrisSC
- Jul 23, 2011
Just get the e11, it's cheaper and wayy better and more powerful.
No I'm not biased, I own both amps. Even though the specs say that the zo2 gives 16db bass boost while the e11 only gives around 6, my ears find it to be not true. They both have nearly the same bass boost power. That's the only thing they got in common though. The e11 is alot brighter and the bass doesn't really overwhelm the entire spectrum even at eq2.
The zo2 bass is mostly bloated mid-bass, it doesn't give you as good a rumble as the e11. Also the bass is very sloppy and just sounds empty.
I've tried using alot of different headphones with the zo2, it just doesn't compare to the e11.
I respectfully disagree. I had both amps, but sold the e11 a few months ago, so this is all from memory, but the e11 was nothing special. It's not a bad amp in the sense that it did what it was supposed to do, and cleanly, but....
I also got noticeable clipping with the e11 bass boost circuit and my es5. As far as the zo bass circuit goes, I find that what you describe as bloated midbass with the zo to just be matter of fuller thicker sound across the spectrum.
To each their own, but I know which one I sold and which one I kept
