paulguru
- Dec 27, 2014
using muses02 opamp the headphone amplifier gain will improve ?
Thanks for the replies guys. I think I have it a little better now. I left Windows at 5.1 but changed the SBZ control panel to Headphones. I have the bass control back and it makes sense how it works, so I'm assuming I'll have better surround in games. I also did one other thing while trying to hack an audio output for the Buttkicker.
I ENABLED my Realtek onboard. I went to the "What you hear" recording channel, selected "Listen to this device", and pointed it at the Realtek speaker channel. It works, with one caveat. There is a small but noticeable and annoying delay in the audio going to the 2.1 speakers. Maybe 1/4 to 1/3 second. Going to look into this more in case there is a way to reduce processing and speed it up a bit. Seems like there should be a better way to do this though, short of adding a splitting between my DAC and AMP, as I fear that feedback would greatly reduce the quality of the audio I spent so much time and money improving :/
A splitter should not have any audible impact on the sound quality, I'd say try it - high quality splitters are only a few bucks, and if you really hate it (for whatever reason) then you can go back and futz about with the ganged audio cards.
The problem there is that I think the Buttkicker is a single channel. I could split just the left or right channel from the Modi but then I could get lopsided shaker response or headphone performance/quality. Alternatively if I split off both channels from the Modi, then used another splitter to combine that into a single shared mono channel for the shaker, Id essentially be crossing the left and right channels and ruining the headphone audio.
I was thinking a better route may be an optical spitter and a Fiio D3, but that only goes to 20hz (whereas the shaker and the soundcard go to 10hz) and there could potentially be timing issues there as well. This is also assuming that the shaker can work with the line level output of the D3.
I'm going to try a few more settings on my SBZ tonight as well. I was trying to use the 3rd center/subwoofer jack, but it may be possible that the front channel or headphone outputs still work with optical. I also heard that I can maybe set SBZ control panel to stereo speakers instead of headphones to get the same audio mix to my headphones, and this could potentially allow the other outputs to work. I'll find out tonight.
I have SBZ and I'm looking for STX II or something better then STX II ?
I have one free PCIE slot in my case
WRT other stuff on the Z itself - you cannot have the front L/R output and the headphone jack active at once, but you can have either of those jacks (headphone or front L/R) active alongside optical - if the card is set to "speakers" it will output via front L/R + optical (with "play digital mix" enabled), if it is set to "headphones" it will output via headphone + optical (again with "play digital mix" enabled). The volume control for the system will impact the analog output in either case (to adjust digital level you go into the mixer and draw down the left/right for the digital output) - in theory you could connect the TT's amplifier to either the headphone or front L/R output directly from the Z, but if the TT only takes a monophonic input you will still need a summer if you absolutely must see both left/right connected to the TT.
I have SB-Z and I'm looking for STX II or something better then STX II ?
Well I have Presonus HD7 headphones and Takstar 2050 and Logitech Speaker System Z906.I need buy and speaker with very good audio quality performance,because Logitech Speaker System Z906 is very low.
