shagrathborgir
- Nov 22, 2014
No offense but this is insanely hard to read. Please use proper spacing with punctuation and don't rely so heavily on ellipses.
My response to what I can divine you to be potentially saying:
- No, there is no right or wrong way to do this in any sort of objective manner. There are many ways to connect these two components together.
- The Yamaha cannot be fully bypassed unless you remove it from the equation - it will always have signal going into it, and coming back out of it. It cannot behave as a purely analog in-out device, because of the DSP functionality. You would need something much more basic to achieve that.
- Using the analog outputs of the Creative card uses the Creative card's DAC. Using the digital outputs of the Creative card does not use the Creative card's DAC. The Creative card is still acting as a source device and audio interface when outputting via digital, so it's not reasonable to say it has "no benefit" - it's the only reason you're getting a DTS encoded output, for example.
- The signal has to be converted to analog *somewhere* - where it's done is really dependent on the gear involved and what you're after. I wouldn't be so quick to jump on the "this costs more its always better no matter what because it costs more" bandwagon though - high end sound cards (like the Creative) have top-shelf DACs and output sections, and I would be surprised if it isn't using comparable or better components than the Yamaha. That said, differences between DACs tend to be extremely subtle (if even discernible in normal listening), so I wouldn't get too wrapped up in that either.
- Running the DTS: Interactive package to convert stereo music to a 5.1 output, and then relying on the Yamaha's DSP to mix that up to 7.1 is certainly not likely to win anyone's favor as being "untouched" or "unadulterated" - a lot of processing is going on for that signal to be output on a 7.1 speaker system. That doesn't mean you can't like how it sounds, but it's certainly not native reproduction by any means. You shouldn't lose anything with either approach though - you're inputting the same signal, and just changing how it is being output at runtime.
ok,sorry for my writing!
you said,there are many ways to connect these two components,there are only the ways listed by me,plus dolby digital,but from what I know,dolby digital is even more compressed!
is there a difference in titanium hd and zxr when speaking of dts and optical out???I have used 3 or 4 creative sound cards with optical out,and every one of them seem better than the previous,from what I can remember.
from what I see,both of them are using Burr Brown dac's,but can't find the info on what Burr Brown model is used on the yamaha!still,the yamaha amp is more complex than a sound card!
my goal is to send the purest audio signal to the yamaha whit the creative titanium hd,or with onother card,if there's something better out there.maybe changing the stock opamp's will bring me better audio quality!
from what I remember,my first creative card had analog outputs,not rca,but 3x3.5 jack and my other amp had multi ch input.
since you know more than I do,what would you do,and how would you use what I have,or what would you change?thank you!
So,is there something better out there for optical (xonar,auzentech),than titanium hd?is there something better with analog out than titanium hd?
