so,there isn't a right way to do this...the yamaha is not bypassed,but if I don't want to bypass the creative dac,I have only one option,and that is Analog.so nothing digital,dts or pcm,takes benefit of the creative sound card.still,the analog signal,coming from the creative card is not ok,really.I would not pay money for any kind of card,that delivers this kind of audio...is really bad.are you saying that from 10 sound cards with optical out,I'll get the same sound as with creative titanium hd???no point in getting the zxr if I'm using the optical...or will zxr sound better using it's dac's??
or,is a 3-400 euro dac better way than a sound card??I see there are dac's with optical and analog also.
I always thought that pcm will use the internal dac...I'm really lost!
Another thing,it music is digital,why convert it to analog by a 200 euro sound card,and send the signal to yamaha (whici has far more better components) to do another job,when yahama can be the end of the line!still,that's they my point..I thought that PCM will be the better choice...since is digital,and only 2 ch like all recordings.
if I get it right,in dts mode,from 2 ch audio...I send 5.1 to yamaha,then the yamaha makes 7.1...do I loose something on the way??so much money,and so many things,and I don't feel this is right,as I want pure music,just like it was recorded,with no loss of details!thank you for youre time
