- Jul 22, 2011
Clieos, how would you define the term "sweetness"?
Forwardness, texture, detail, and intimacy in vocal. Essentially, it is how close the singer is to the listener in the virtual space and how well that voice converts emotion - or if you like, how well it makes you feel like you are there. If a headphone can make you feel like you are right next to the singer and let you listen to his/her breathe between the lyric, I'll say that is sweetness in its element.
is there any iem that meets the sound signature of the sony ex1000 but with less highs and of course less quality on a budget?
ok, let me correct my question a little bit. when i say "rolled off highs, smooth, spacious, sub bass rumble, under 1500 dollar" what comes to your mind? the ex600 cost about double the price here.
nice!! now, how would you define "dynamics" ?
and, after that, which one has better dynamics: RE262, FXT90 or GR07?
sorry, yes 150. well the ue700 have everything but rolled of highs and subbass rumble.
Actually the high does roll-off a little - well roll-off might not be the right word but UE700 isn't bright at all. As for sub-bass, not that many IEM can do it well, so it isn't that big of a deal if you really look into it.
Though never formally announced, there are two version of VB. Any VB review predated this year are likely the original VB and anything within the year are VB v2.
