Concise Multi-IEM Comparison (FINAL UPDATE March. 1st, 2013)
- Thread starter ClieOS
- Tags
- altec-lansing-inmotion-im716 audio-technica-cks70 creative-aurvana-2-in-ear-headphones etymotic-er-4p-portable-in-ear-earphones etymotic-research-er4s-micropro-reference-earphones fiio hifiman-re-400 in-ear jays-a-jays-three jays-a-jays-two jays-t-jays-one meelectronics-m-11 mp4nation-brainwavz-m1 mp4nation-brainwavz-m2 ortofon-e-q5 shure-e3c-sound-isolating-earphones soundmagic-pl-21 vsonic-gr06-pro-dynamic-noise-isolation-earphones-earbuds westone-um2-stage-monitors
Emospence
- Apr 7, 2012
ClieOS,
What tip would you recommend for TDK BA200?
I uses the stock large bi-flanges myself, but Etymotic / Westone tri-flanges, and most of Shure single flanges should work just as well. For foam tips, Shure olive (black foam) works out well, and so is Comply Ts100. For overall durability and comfort, I'll recommend olive first. Just one thing: be careful when you remove the eartips as the filter might come off at the same time (or stuck in the eartips). If so, just take the filter out and reapply it onto the nozzle, not need for a new one.
kanuka
- Dec 12, 2010
talking about ety-triple, how well do they work for the B2 or DBA 2 ?
Pretty good, as long as you don't feel like being offended by tri-flanges.
kanuka
- Dec 12, 2010
triple ones dont fit my ears
, BUT i trim the small upper flange and make a bi-flange, which do marvel. great fit comfort and isolation
WakiDabeast
- Feb 13, 2011
hey sorry just another quick question about what would you rate the A03 for soundquality?
Sorry, I am still a bit far from reviewing A03 yet and I don't want to jump to conclusion when I haven't spent enough time on it.
Emospence
- Apr 7, 2012
Shure single flange includes grey/black soft flex?
Yes, as long as they are for SE series.
Emospence
- Apr 7, 2012
Thanks, will give them a shot.
Emospence
- Apr 7, 2012
Anyway, I got mine at 159 SGD, about 12x USD. How would you rate their value at this price?
Worth investing more in my search for the perfect tip for them?
You are getting a tremendous bargain. I'll say it is still a really great buy at US$200.
- Jul 22, 2011
It's a big bargain, Mother of Dragons.
vwinter
- Oct 6, 2010
Is this a store that ships to the US?
