Ewen
- Mar 17, 2016
yes it is definitely a great budget DAP. And it makes for a very compact and great sounding rig when paired with the XQ-10
How do these iems sound?
That's the 1 DD + 3 BAs from AE?
5BA less than $180 USD
Look what I found on AliExpress
http://s.aliexpress.com/yauY3EB3
PMV A-01 MK2 review for those who might be curious about them:
http://www.head-fi.org/products/pmv-a-01-mk2/reviews/16594
Ordered **** 4in1 with MMCX cable. Easy earphones says with MMCX cable. But I just noticed under my order it says Silver no cable. I tried contacting but have not heard back yet. What should I expect?
I have the A01 and my only problem sonically is a 3 kHz peak, do the mk2 sound the same around this frequency?
@1clearhead @CoiL How is the MOD MAN in hlsx-808 ?
Great impressions and information for budget-gear fans! Thanks a lot! Hopefully my **** 4in1 and Magaosi BK50 will arrive very soon (4in1 should be closer).
About to place my order for the 4in1 and wanted to see if people have tried both the black or blue cable and if they noticed any sound quality difference?
That seller is banned from discussion on this forum
@1clearhead any cable with mic that you'd recommend to go with **** 4 in 1?
What happened to get the seller banned? I must have missed it.
tks manMake sure you have the thicker pads on place and use the straight cables instead of the curled ones. The straight cables are the ones made for professional use and enhances the bass/sub-bass region.
