So I ordered the zs3 like a week or 2 ago and no tracking info. I msged the dealer and he said to be patient and wait 2-3 days and I have and no tracking, what should I do?
Chinese / Asian Brand Info Thread (Headphones, IEMs, Amps, DACs)
- Thread starter bhazard
- Tags
- havi-b3-pro-1 somic-efi82mt somic-hd-mh463-open-air-dynamic-pro-headphones-black somic-e-95-v2010-real-5-1-surround-headset somic-mm163-8hz-30khz-professional-studio-monitor-stereo-headphones-with-ccaw-voice-coil dunu-dn-2000-hybrid-3-way-earphone takstar-pro-80 xiaomi-pistons-2-0-mk301 dunu ostry-kc06-high-fidelity-stereo-inner-ear-earphones somic-head-band-music-audio-headphone-earphone-headset-mh489
- Status
- Not open for further replies.
bjaardker
- Nov 11, 2009
Finally got the Vivo XE800.
Packaging: Plastic Bag...that's it.
Accessories: 6 silicone tips.
I bought from rilpac or whatever they are, so I'm pretty certain they're real..
I'd love to give you other impressions, but no matter how I swivel the nozzle, I can't seem to get them in far enough to get a decent seal. Cable down the strain relief and cable push on my anti-tragus. Cable over ear the strain relief pushes on the anti-helix. I have over 15 different pairs of IEMs and the only other time I've had this issue was with the TRNDLabs COAL Organic. https://www.trndlabs.com/product/coal-organic-earbuds/
I'm going to try some tip rolling with foamies and dual flanges later this evening to see if I can work out some sort of shallow seal. Otherwise, these may end up being a failed experiment for me.
hakuzen
- Feb 9, 2016
adding some spacers to the nozzle, you can get a few milimeters deeper insertion, while keeping the shell shallower, so it does not push on your ear
hakuzen
- Feb 9, 2016
something like this:
Turkleton
- Nov 9, 2015
tfz series 1s fireworks now just $40 on AE
How do they sound? Because damn... do those red ones look oh so sexy!!!
Lurker258
- Jul 8, 2016
I love my rock zircons, but does anyone know an IEM that is a step above the zircons while having as much bass as the zircons. I tried TFZ Series 1 but while it definitely has more mid-bass, I found that the sub-bass rumble on the zircons was much stronger. I also tried Maples but to me they lack bass.
Skullophile
- Dec 18, 2012
Bear in mind the above impressions come from his friends audio store where he/she did a brief audition of them lol
loomisjohnson
- Jan 31, 2014
The t
[the tennis dulcimer is superior in every way, bass and crystal clear
bjaardker
- Nov 11, 2009
Interesting, did you just find rubber bands or something that were the right size, or did you purchase that from somewhere?
hakuzen
- Feb 9, 2016
got silicone/rubber o-rings of many sizes to have spares for vape gear (but found many applications afterwards).
found them cheap (at last, after months of research and trying in ebay and online stores) in fasttech.
you can find 1mm, 1.5mm tall o-rings there (suitable for acting as separators).
these are silicon 7.8(OD)x5.6(ID)x1(T)mm o-rings (too wide for XE800):
https://www.fasttech.com/products/0/10006772/1886601-silicone-o-ring-seals-for-atomizers-50-pack
but you can access to every sizes from these links, for example:
https://www.fasttech.com/products/0/10006430/4616912-rubber-o-ring-seals-for-e-cigarette-50-pack
https://www.fasttech.com/products/0/10006430/4625003-rubber-o-ring-seals-for-e-cigarette-50-pack
Edit:
if diameter of the nozzle is 4mm, try o-rings with 3-4mm(ID) (5x3x1, for example). if they are tighter, they'll keep quieter when applying pressure from the tip, and they won't go beyond the lip.
some nozzles have a very narrow lip to mark the limit for the tip; in that cases, you can stack some o-rings from the shell to the lip, so they act like a tougher lip (whenever there are not vent holes in that part, like in the "noname").
Does anybody know about the wrz x6?
I am looking something that I can use at the gym. Maybe zircon sports?
Pastapipo
You can also cut off a bit of the 'base' of an old tip. As long as the nozzle is the same size.
Its unfortunate that they dont fit you in stock configuration, hopefully tip rolling will do the trick.
Don't forget to give them a proper burn in.
kimD
- Feb 5, 2016
I saw Easy earphones selling the 4in1 for cheaper than HCK. Could there be a difference between the two?
Nothing to compare here.
Anyway you can ask the seller do one time offering for you as before you pay by card
kimD
- Feb 5, 2016
Last time when have QT5 vs D2 and everyone crazy with these.
Nowadays what's the IEM coming up?
4in1
- Status
Total: 17 (members: 0, guests: 17)
