CoiL
Member of the Trade: Wood Audio Accessories & Modifications
Closest tips to those grey ones seem to be Piston 2.1 brown tips, they have almost same diameter bore but difference is in inner bore shape - greys have it widening while P2 tips are straight walled tube. P2 tips do sound slightly bassier tho and soundstage "naturalness" isn`t so good.
To test it out - just close them with tiny piece of tape. I will close them permanently with gel-super glue.
I close the vent hole with some tape.
Now I think these 808 are amazing for the price !
Bass is cleaner, tighter, deeper, very impactful. Treble is more natural.
Overall the sound is more controlled and more natural.
It still has a bit too much bass presence. Will try the creative tips in a few weeks.
I don't feel the need to buy BK35 right now, which is good for my wallet.
Thanks
Good to hear You having same improvements! Did You closed them with glue or with tape? I recommend it seal properly with gel-superglue if You like it.
Also try P2 brownie tips too if You have them.
If they drop to 35$ and get some positive impressions, then I`ll think about them again but until then listening to my RAW-mod.
Btw, while I think soundwise creative 930i tips are best for 808, then I`ve settled with piston 2.1 brown tips with my 808 because of wear fatigue (930i tips cause little stress & aching after longer listening, probably too hard and wide bore edge pressuring on ear-channel.
I tried different medium sized tips and to my surprise I could also get good fit with piston 2.1 medium tips.
Anyway, best tips for 808 are Piston 2.1 browns, JVC Spiral Dot and creative 930i. Certainly recommend to try one of these and others with tip-rolling.
I just tried Piston 2.1 tip on my 808, and I do like the sound of it more than stock or foam tip that I am using. The stock medium size tip is too big that I can't get a good seal in my left ear while stock small size is too small that it's loose. Thanks for sharing.
Good to hear! I also like the sound and comfort of P2 tips.
Do you know where I can buy these tips?
I don`t know unfortunately. You probably have to buy them. Luckily there are many rip-off fake Piston 2`s out there, so You could get those cheap with same tips
Guys, I really like what I`m hearing out of 808 RAW-mod - very big soundstage and excellent separation, midrange is improved and bass tight & textured.
Atm listening to Devin Townsend - casualties of cool album and it sounds so open, detailed and natural.
I do think 808 has made bad step with this housing design. That dynamic driver they are using needs smaller chamber and limited air movement to act accurately and sound like it should.
so, for those who want "best" out of 808:
1) close nozzle vent holes
2) use Piston 2 or creative 930i tips.
