Chinese / Asian Brand Info Thread (Headphones, IEMs, Amps, DACs)
Status
Not open for further replies.
Aug 4, 2015 at 2:41 AM Post #16,951 of 35,472
www.zionote.com/2012/exs/x15/
Anyone tried these? Search came up with nadda. Found em while hunting for some JVC stuff.
Edit: EX20 uses dual drivers, Knowles;
www.zionote.com/2012/exs/x20/
Edit 2: There's a lot of neat stuff on that site actually. Too bad I don't speak Japanese.
There`s old H-Fi thread for EXS-X15 actually and they seem to be Korean: http://www.head-fi.org/t/632842/koreas-exs-x15-new-single-ba-model-w-detachable-cables
Aug 4, 2015 at 2:45 AM Post #16,952 of 35,472
I recall that EXS IEMs were discussed by @ClieOS on his blog inearmatters.net.
these are not really "new" havi tips. they actually come when you purchase the Havi B3 as a package.
I bought two pairs of HAVI B3 and they did come with foam tips. Just not the ones with the hole on the side. I was wondering what is the purpose of this hole.
Aug 4, 2015 at 4:09 AM Post #16,953 of 35,472
http://www.ebay.com/itm/EXS-EXS-X15-Single-BA-Unit-Detachable-Cable-Earphone-EMS-Free-Shipping-/281265669555?hash=item417cbd85b3
Aug 4, 2015 at 6:32 AM Post #16,954 of 35,472
I see. So these are not identical to the ones that I had received with Havi B3.
Thanks for the information.
Aug 4, 2015 at 11:16 AM Post #16,956 of 35,472
  trinity delta or titan? soundstage matters most, novice audiophile, would like the best bang for my buck. Thanks in advance
If soundstage is your main concern I'd go with the Titan between the two.
You might also want to take a look at the Soundmagic E80.......
Aug 4, 2015 at 11:27 AM Post #16,958 of 35,472
what is the soundmagic's strength? how well does all these headphones perform in edm, rock, and pop?
The E80's are not the best for EDM but very good for pop and rock.
Its strength is subbass (more than the other two), soundstage, separation etc. I'd actually rate them higher than both the others but they dont have much mid-bass and because of that are not the best (but still good) for EDM.
Aug 4, 2015 at 11:34 AM Post #16,959 of 35,472
+1
Aug 4, 2015 at 12:11 PM Post #16,961 of 35,472
so soundmagic? is the performance in edm worse than piston 2?
No but it does have less mid-bass.
The Titan is really nice with edm but the e80 is better with pop and rock....
Aug 4, 2015 at 12:16 PM Post #16,963 of 35,472
soundmagic seems tempting, i think im gonna go for it. Any idea for what i should do with the remaining 30 dollar? a amp maybe?
Good question, I'll answer it wit another: what's your source /player :wink:
Aug 4, 2015 at 12:24 PM Post #16,965 of 35,472
most of the time, a nokia lumia 710 sometimes a xiaomi mi3
Ok, I'm not familiar with those. The e80 needs more power than your average iem but they work ok even from my Sony z3c which has a very weak power output.
The only amp around that price that I've tried and that I feel actually is worth it is the Topping nx1. It doesn't work very well with phones though because if emi issue.....
Let me know if you'd like me to try the E80's with the nx1 and see how it sounds.
Status
