- Sep 22, 2011
Drgajet|2xl|2
Drgajet|m|1
Drgajet|m|1
I'll be sure to bring some In-and-out back to slowly waft in the direction of the non-lunch people.
Stay updated on headphones.com at their sponsor profile on Head-Fi.
You monster!
I may have thought about doing the same~
Also does anyone know what is going on with the member showcase?
Lol, I do. Been busy with the various print deadlines, but I'll touch base with ya tomorrow.
Thank you, and sorry to bother you. I know you are a very busy man.
Recommended to turn volume all the way down, put headphone on, then press play. Some headphones may distort when they are not on your head due to acoustic damping. If a previous listener turned the volume up too high, and there's bass playing before you put the headphone on, then you'll hear distortion when it's your turn, even when you reduce volume. This goes away after a while as the diaphragm adjusts itself, but immediately, it'll be a problem.
Note: my headphones won't do that, as I know how to "fix" the problem, so you don't have to be reserved about volume on mine. But some others will do that, and then funny things will happen, so please try to take good care of others' gears.
