Calling All "Vintage" Integrated/Receiver Owners
Apr 15, 2014 at 2:56 PM Post #12,316 of 19,141
  I'm curious what people are doing as far as subwoofers and low pass filters and high pass filters with vintage gear.
I'm using an SX-750 with some Pioneer bookshelf speakers and a subwoofer. I'm using the line level inputs on the sub and using the crossover knob on the subwoofer itself which is no big deal. The sub is crossed at about 60hz. The thing that bothers me most is that I'm running my little bookshelf speakers full range 20hz - 20khz. I'm using them near field so it's not taking much power to get them going, so I'm not too worried about them trying to play the frequencies below 60hz or so. For the first couple weeks I used these bookshelf speakers with the grilles off so I could watch the cone excursion and to my surprise I never saw them moving all that much even on the bassiest music. I'm just curious as to what people are doing here in this regard.
My speakers have a sensitivity of 87db at 1 watt at 1 meter. Using a digital Radio Shack SPL meter I never see myself listening at higher than 90db, even on peaks. I'm always listening somewhere in the 70-85db range. So looking at the math it seems that I'm never giving these speakers more than 2 watts each. Most of the time, especially night time listening when I listen at under 80db, if the math is right they aren't even getting a full watt each. This seems crazy low and hard to believe, but if this is true, then these speakers should have no problems being run full range.
If they are really 87db at 1 watt at 1 meter then here is the math, +3db = double the power.
87db @ 1 watt
90db @ 2 watts
93db @ 4 watts
96db @ 8 watts
99db @ 16 watts
102db @ 32 watts
105db @ 64 watts
Is anybody else running small(ish) speakers full range on their vintage amp? If so, have any comments or concerns?
I'm using infinity entra pointe 5's (small guys) on my sony str-6120 with a separate powered woofer. They claim a frequency response between 50 and 20,000 Hz. That being said, a lot of music has frequencies down to/below 20 Hz in the subsonic region. I find that when I try to feed a lot of bass to the small speakers, they'll keep taking power until the cones bottom out (which is reeealy bad for them). If you take a bit of the load off their bass, you can A) turn your music up louder and B) get much better bass reproduction. Remember that the stated roll-off frequency is the corner frequency, defined as the point at which the response is -3dB (3 dB down) from the average response. This means that the point at which you start losing the response is likely many Hz higher, possibly as high as 500Hz for a 1st order system, but likely closer to 100-150 Hz for more sophisticated speakers (based on box volume if not ported & x-over design). If you have access to their response curves, you should ideally try to set your woofer x-over frequency so that the combined curve is a flat as possible (though I personally like a little sub&ultra sonic boost). I have mine set at 100 Hz, for comparison.
Regarding filters, I don't use them in my system. The bookshelf speakers have a nice roll off and the woofer has a tuneable cutoff LPF that nicely picks up the slack. I just adjust the gain on the woofer to get the desired response and take advantage of the natural roll off of the bookshelfs to get a nice effect.
Considering that your speakers are not played very loudly, it is not at all surprising to hear how little power you use with them. Rule of thumb, about 1 watt will give nice conversation level music, 2 watts will be loud enough to be distracting, 4 watts will overpower conversations within 10 feet, 20 watts will shake the windows of a studio apartment, and 60 watts will make a normal suburban home very loud inside throughout and probably loud outside as well. Anything more and the cops are coming/ you will need a bouncer for your night club. Unless you like a lot of bass, in which case quadruple all those numbers to feed your hungry subwoofer(s).
I run somewhat inefficient speakers on my main system (sx-1980, mcintosh XR-250's), but even at 10w/per, I am overpowering every other human or mechanical noise in the house. Including my terrible attempts to sing along haha. Lucky me.
You might still think those are all small numbers. They are. Marketing people long ago realized that people want more power and BIGGER numbers sell more units. There is a whole bevy of marketing math lies that are told to inflate specs. If you deconstruct the math going into a car power amplifier that claims "1000W", you might find that they are actually more like 20 rms continuous into 8 ohms after you get past all the smoke and mirrors. Don't get me wrong, 20 W will shake your guts when it's all bass in a small car, but it's a far far cry from 1kW.
Apr 15, 2014 at 3:28 PM Post #12,317 of 19,141
87db @ 1 watt
90db @ 2 watts
93db @ 4 watts
96db @ 8 watts
99db @ 16 watts
102db @ 32 watts
105db @ 64 watts
I guess it's relative, but I am running my DX-3 Cerwin Vega speakers (10" woofer) out of my Spec 2 amp (rated at 250wpc, but tested at 310wpc), so they are woefully under spec for the, um, Spec amp output.  Certainly on paper they are but the reality is I've never ran them over 50wpc peak on my power meters on the Spec, and THAT was loud.  No need for a sub with my setup as it already can rattle literally the entire top floor of the house at a reasonable 10wpc (roughly).  CV's are very efficient, tho I'm not sure of the rating, but if I remember right it's like 97db @ 1 watt so it doesn't take much to get them moving.
Apr 15, 2014 at 9:44 PM Post #12,318 of 19,141
I finally arrived home this evening from storage with all three vintage lovelies in tow. I'm going to have play dates from tonight thru Sunday. I've the G-22000 on one dolly, the SX-D7000 & SX-650 on another. The return of my newly hardwired HE-6 prompted this move despite lacking any real open space.
Considering how motivated and creative we become in this hobby to make things work out, it wouldn't surprise me if the devil himself was a vintage gear collector!
Apr 16, 2014 at 12:23 PM Post #12,319 of 19,141
Happy holiday listening!!
Apr 17, 2014 at 10:44 AM Post #12,320 of 19,141
What do you guys think of a Sansui G-5000 was made between 1978 -1980 is it warmer sounding than the Pioneer's SX line ,i have a SX 750.  .Is it worth it for $175.00 are parts available also . Thanks.
Apr 17, 2014 at 11:46 AM Post #12,321 of 19,141
I haven't heard the G-5000 but I do think that is a good price if it is in good condition. It was $470 when it was released in 78.
The stereo-typical sound of 70's Sansui is more silky/warm than Pioneer ime. Whether it will be better for you than your SX750 however, no one can tell you. But theres only one way to find out! Sansui are my favorite vintage make.
It is a lovely looking machine, and it does have a 20db mute which is ideal for headphone use.
Apr 17, 2014 at 1:06 PM Post #12,322 of 19,141
My Pioneer SX-1250 is quite bright (maybe a bit much for me - but could be fixed with other speakers).  A real contrast to my Rowland amps which would be classified as dark.
Apr 17, 2014 at 4:06 PM Post #12,323 of 19,141
Good thing I don't live in the Great White North, I'd get a speeding ticket on a Jet-ski if snow tried to prevent a quick purchase!
 That thing is gorgeous and I do love the sound of my former G-22000, so there's my vote.
A few parts may prove unobtainium but there will still be replacement parts, just not always original.
Apr 17, 2014 at 11:15 PM Post #12,325 of 19,141
Sweet looking piece
Apr 18, 2014 at 3:19 AM Post #12,326 of 19,141
I snagged a fully-functional NAD 3020a from Goodwill today for $25, not too bad. The HP out on it sounds great.
Apr 18, 2014 at 3:42 AM Post #12,327 of 19,141
You are a winner today buddy! Those normally go for at least $200 for good condition. But thats also a rare silver face version.
I've got my HD800 plugged into one as I type (later "i" version) and I agree the hp out is great. I was that impressed with it I bought a further 3 NAD amps for use with headphones. Such a natural tone - a little dark but well balanced and controlled. They have a very addictive sound quality imo, especially if you are after a more analogue like sound.
Apr 18, 2014 at 9:07 AM Post #12,328 of 19,141
Does the headphone out relatively tame the "brightness" of the HD800?
Apr 18, 2014 at 10:32 AM Post #12,329 of 19,141
"a little dark but well balanced and controlled."
Sounds like you are describing a Marantz 22XX.
As soon as I get a functioning HD800 cable, I will try it with my recapped 2226B and report back.
Apr 18, 2014 at 11:46 AM Post #12,330 of 19,141
Where do you guys keep finding Goodwill stores with such great gear? The best thing I ever found at mine was a $15 Onkyo CD player that wouldn't play the first track of any CD.
