A few of my impressions from
this thread:
Hi waynes, mind letting me know if the C&C BH carries a specific sound signature of it's own. Is it a warm or cold sounding amp? Many thanks.
If you haven't already seen the C&C BH thread,
here it is.
I find that the C&C BH brightens things up a bit, adds a bit of detail in the treble region, and also tends to open up the soundstage (especially when using the SF switch). Where I find it to be perfect is with a more neutral or darker source. For instance, the Clip Zip is fairly neutral, but with the C&C BH, the sound really opens up more resolution is added. So, I find the Clip Zip + C&C BH pairing perfect for my WS99's or CKS1000's (but not with my AD900X's because they have this thing for the Fiio E12 lol).
With a source like the ELE DAC which is already a bit brighter, the Fiio E12 pairs very well because the combination is fairly neutral, and the E12 adds a bunch of power and refinement. And the sub-bass boost of the version 1 E12 that I have is very cool and works very well with all of my headphones and iems. The WS99's sound amazing off of the ELE DAC + E12 with the bass boost off or on. Having said that, the WS99's also sound amazing off of the ELE DAC + C&C BH. Because the WS99's are a bit warmer to begin with, they don't get too bright for me with the ELE DAC + C&C BH combo (whereas I think that headphones that are brighter to begin with would). Also, the C&C's SF switch which widens the soundstage works well with the WS99's. It would be difficult at this point for me to say which amp I like better with the WS99's off of the ELE DAC.
The amp for my AD900X's is the E12 (v1). For some reason, that pairing is just amazing, and the sound is just less coherent or refined when the AD900X's are paired with the C&C BH. It's not that they sound bad with the C&C BH, it's just that they sound perfect with the E12.
My CKS1000's are not as picky though about which amp I use off of the ELE DAC or the Clip Zip - sounds amazing with everything.
I never really intended on having two portable amps, but as you can see, it has become complicated for me lol. So, I'm happily stuck with them both. I find the E12 really isn't all that portable anyway, so it happily sits on my desk, usually attached to the ELE DAC (or used when I watch TV with the AD900X's). Whereas the C&C BH is quite small and portable and has that ridiculous 80 hour batter life and it pairs very well with the Clip Zip, so it's usually dual locked with the clip zip and ready to go.
Hi wayne, appreciate your thoughts with regards to the C&C BH. Will take some time to go thru the thread you have linked. In the meantime, do you feels that the brightness you have observed would causes sibilant or could it helps to smooth out the highs.
Many thanks.
If your source or your headphones/iems are bright, then you'll have to think a bit about sibilance with the C&C. It was a concern of mine when pairing with the ELE DAC because I am fairly sensitive to bright treble, and the ELE DAC already adds some brightness. But in reality, it hasn't proved to be an issue because the headphones and iems that I'm using are not sibilant to begin with. Overall, I am thrilled with the C&C BH. It adds detail, resolution, and soundstage. It's 80 hour battery life alone makes it seem like it
never needs to be charged. It's LF bass boost switch is still a bit of a mystery to me, but I like it (depending on the headphones and music). It's SF switch is like vodoo how it increases the soundstage, especially for live recordings. And it is quite small (smaller than the E11). Pair the C&C with a neutral to warm source or headphones, and it is friggin amazing. So yeah, the C&C BH is a keeper in my books.
