I did a lot more talking at this meet than I did at the last one relative to listening. Part of that is that I'm getting to the point in the ladder that it's hard to evaluate things in meet conditions. I think the solution to this in the future might be to have a few mini meets for serious listening of a few things, in addition to the full blown meets. If anyone would ever like to listen to any of my relatively modest gear, feel free to send a PM.
Its always a pleasure to talk DIY with Nate and Ian. I did some listening to Ian's PPA and M3. This definitely reaffirmed my decision to build an M3 (I've got all the parts on hand, just gotta get my desk cleared off and get it started). What a wonderful amp. Rich warmth at the same time as excellent detail. I think I'll be happy with the M3 as my main SS amp for quite a while.
The PPA was excellent as well, but I couldn't live with one as my primary amp. It's one of the few amps that makes me really like my HD600. The problem is I find it way too bright with my HF-1. I'll probably end up building up a PPA eventually, but it's pretty far down the list. Based on a quick listen, the millet hybrid sounds pretty good with the prototype diamond buffers. I'll go back and give that a more extended listen once the M3 is done and I start looking for the next project.
I also picked up my pre-ordered Hornet from Ray. "What's a DIY guy doing buying a commercial amp?" you say. Well, I heard the prototype at the last meet and was amazed. Ray's put a ton of work into tweaking this design, and it shows. Also, I'm not nearly patient enough to do such wonderful casework on an amp so small. I think I'm done, portable amp wize. All the features you could want (gain switch and battery recharging are great) in such a tiny package with amazing sound. The more I listen to this thing, the more I like it. After I've had it a while, I'll post a more serious review. Maybe I'll find a negative by then
The surprize star of the meet, at least for me was Dave's modded Ipod Nano paired with the hornet. The sound coming out of this little shirt pocket sized rig could put plenty of home rigs to shame. If I can break down and buy an apple product and swallow the ~$200 for the mod, I think I'll be set for years as far as portables go (minus cans). Good thing for my wallet I can't just audition someone's custom fit sensas or ue's.
I spent a little bit of time with Yikes' K501, enough to whet my appetite for a further audition. I'm planning to eventually own a can off the beaten grado/sennheiser path, and the 501 (and it's pending big brothers) has been added to the short list. Headroom's HD595 was interesting, but I don't think it's for me. I like it's more forward sound relative to the 580/600/650, but it still doesn't have the visceral emotive power of my grados. I really liked Haj's Zeta Flat pads on the HF-1. Once the rest of my rig has settled down, I'd love to do an extended comparison of Larry's different pad options.
I did some listening to the Maxxed Headroom Desktop. I liked it a good bit, but I don't think I'd ever buy one. I just find I don't care for headroom's amps. I find them to be the sennheiser of amps. I appreciate their technical merit and quality, but I just don't fall in love. (Except for the Max Balanced, which, ironically, I like best with Senns.) I do love their DACs though (I'll recommend my microDAC to anyone who'll listen) Tyll, you realize I'll keep bugging you to make a standalone max balanced DAC until you give in or retire, right?
Thanks to Dave, Haj, and anyone else who helped to put this together. Thanks to Ray, Tyll, and Mikhail for supporting this community and bringing gear for everyone to try. Thanks to everyone else for coming out and giving them a community to support. These meets are great fun. I can't wait for the next one.
