RicHSAD
- Jun 29, 2009
I've been getting some of my cables from Infinite Cables. They basically sell Phantom Cables. They are Canadian based, but they ship to the US. Not sure for how much though.
Having tested cables ranging from 77c to $139 for noise and FR I suggest either Monoprice or Tartan cables, the Tartan are a bit pricier $5 vs $2.39 but they are a bit easier to work with (less stiff), functionally and audibly they are indistinguishable. None of the more expensive cables I tested were notably different on noise or FR apart from some silver cables which had a small noise spike at 8k.
If you really have to spend more money the Blue jeans cables tested equivalently to the Tartan and Monoprice.
If you would like to hear the (non) differences between the cables I tested I have posted some samples on the "my Cable test enterprise" thread.
To date nobody has been able to reliably identify the differences between the cables used.
Remember, the laws of physics are indifferent to how much money you spend and how much you like the physical appearance of cables.
Did you actually listen to all the cables you tested?
Quote:Having tested cables ranging from 77c to $139 for noise and FR I suggest either Monoprice or Tartan cables, the Tartan are a bit pricier $5 vs $2.39 but they are a bit easier to work with (less stiff), functionally and audibly they are indistinguishable. None of the more expensive cables I tested were notably different on noise or FR apart from some silver cables which had a small noise spike at 8k.
DNM Reson -I believe that this cable is the best value for the money in the price range (around 100Euro); this cable have a warm sound (not edgy sound) a sweet midrange and good, deep bass. On the negative side, DNM have a little bit small soundstage than the rivals and maybe not so dynamic.
I have try many cables in this price range and near (Profigold pga3000, Qed gunex3, Qed qunex silver spiral) but believe me, none of this cables have more natural sound signature than DNM.
