dryvadeum
- Jan 6, 2013
I just got my LCD 2's today and I'm loving their sound. I think I have finally found the sound signature I have been seeking.
Owning both HD800 and W5000, I definitely think the HD800's is orders of magnitude better.
Everyone I give a listen to the HD800 is gobsmacked by the quality of sound.
Everyone I give a listen to the W500 geta s sour look on their face and asks for something better.
The only reason I keep it is because it is a flagship of AT.
You will notice in my sig that I don't own an Ultrasone.
I have listened to 3 different models including the ED10 and find them awful to the point of not owning one.
There are a few of the last entertaining posts missing....would like to know why.Censorship at it's best!:wink_face:
Out of curiosity, what type of music do you listen to?
I love both headphones...I just found the W5000 to work better with string sounds.
It could just be the particular recordings I have.
I own HD800, W5000, AKG 701, sennheiser 595, and Beyers 990. The best for classical would be a toss up between the W5000 and HD800s. Another question: what are the "best" headphones for classical (i.e., piano concertos and symphonies?). I was contemplating getting the Audeze LCD2s but I heard they have recessed highs.
I agree that it is muffled and doesn't sound as good if they are paired with a bad amp. However I must add that the coloring of the HA5000 is as extreme (some may disagree) as the W5000, that it can change the sound of a headphone dramatically, especially with the W5000. I have never heard a headphone that changed more, other than the W5000+HA5000 combo. Of course, the nasally tone is still present, the main sound signature doesn't change (that much), but the pairing of the combo works much much better than other amps. The issues of bass is resolved with the pairing because the HA5000 adds a lot of bass.Every aspect of the W5000 is improved. If you ever compare the W3000 and W5000 on the hA5000, you will realize that the W3000 sounds much worse than the W5000 on the same amp, because the amp was designed specifically for the W5000, and I believe Audio Technica intended the pair to be used together. I don't think any company will create a flagship that will be deemed worthless by its users.
As I said in the previous post, another user in China tried the Millet with W5000 and thought they sounded awful, until he tried the HA5000 combo, which he thought sounded amazing, but had no idea why that W3000 sounds so good on the Millet, while the W5000 sounds so bad. Perhaps you should try the combo one day!
From a neutral stand point however, the combo is no where NEAR neutral. It is extremely colored in a airy, spiritual way, unlike the meaty coloring of the W3000. Luckily I have the UERM to show me where neutral is, after long listening periods with Audio Technica headphones!
I would also like to add that I use my W5000 to listen to female vocals only, because I find that is what they excel in. Classical honestly do not sound very good on them, since they have a very sweet sound signature (sweeter with the HA5000!)
At which frequencies do you hear the resonances? I want to try listening for them, I seemed to have missed the resonances during my listening periods.
