shotgunshane
- Sep 25, 2010
A removable cable connector would be practically larger than the housings of the rockets. Not going to happen in my estimation. Have I mentioned these things are tiny?
no cable is ever that durable. It's wishful thinking. I wouldn't have an issue with the cable if not for the fact that these iems will be going for $250 retail. $200+ is high end. Hifiman re400 changed the game at $100. If you want to stand out at $200+, you must include user replaceable cables. Just imagine $200+ over the ear cans with a non user replaceable cable. It just doesn't really exist anymore.
Very good question. I think we will probably make that one of the reach goals during kickstarter campaign. What other options do we need to look at?
The problem is that a replaceable cable that wasn't planned would require a large redesign at this point.
I personally would like reassurance of a well designed cable entry point because there appears to be no strain relief. Apparently it can be done well and without large issue a la Ocharaku.
The strain relief could actually be inside the housing itself... Some manufacturers do this.
Actually there are plenty of full sized without replaceable cables over 200. It would be nice but not a deal breaker for me if it's not detachable.
Vsonic vc02 has a user replaceable cable. It's pretty tiny. I think it's conceivable. I feel like they are allowing us to say our peace and I am going full throttle. Not going to pass up on the opportunity.
Yea that's kind of what I mean, but I guess my concern would be the housing cutting into the cable over time, unless the design takes this into account.
OH!
Please, a plug that fits through a smartphone case! Please
OH!
Big yes to the last one! Big yes to the last one! I hope you're reading about Dale... That definitely needs to happen! I'll reiterate because to the consumer (non-pro, this is a deal breaker often): A plug that fits through a smartphone case! It's so important that I'm going to add it into my above post too!
