Audiobyte Hydra Stack: Hydra.Vox + Hydra.Hub + Hydra Zap
Mar 19, 2024 at 4:36 PM Post #886 of 915
Tonight I listened to music with the new solution suggested by m-i-c-k-e-y.
I tested for differences before my brain got used to the change.
The improvement is there.
It's hard to explain... it's like a beautiful sunny day that suddenly becomes clearer and brighter where the colours stand out more and break away from the background.
Thanks for the tip it's a great upgrade
Mar 19, 2024 at 4:51 PM Post #887 of 915
Nice addtion for 220Eur right? Enjoy!
Apr 1, 2024 at 2:00 PM Post #888 of 915
Buon pomeriggio a tutti.
Ho notato un rumore tipo crepitio quando riproduco con Roon (Qobuz) i file FLAC 192/24.
Lo fa solo con questa risoluzione nonostante tutte le impostazioni dell'HUB.
Vi chiedo se succede anche a voi o se magari non ci avete fatto caso. Per comoditΓ  vi dirΓ² l'album in cui Γ¨ piΓΉ frequente.
Shelby Lynne - Solo un po' di amore
Apr 1, 2024 at 2:17 PM Post #890 of 915
Precisely, IME, have those cracks if I don't have a good/solid connections with LAN/RJ45 connectors. Glad you have solved it.
Have Shelby Lynne's "Just a Little Lovin'" album but on DSD64. Tried some 24/192 materials right now, and don't have (anymore) such issues.
Apr 7, 2024 at 3:34 PM Post #891 of 915
Good evening, everyone. I ask a stupid question but I swear I didn't understand.....
If on VOX DSD DIRECT is set to ON everything that arrives via USB or I2s is converted to DSD 256/512 right?
If so, another question: is it converted to 256 or 512?
If DSD DIRECT is set to OF, does it not convert to DSD?
Thank you for a clarifying answer.
Apr 7, 2024 at 4:12 PM Post #892 of 915
DSD DIRECT ON: Convert to DSD 256/512 (depending on FW), "Direct" to output (Preamp/Volume function bypassed).
DSD DIRECT OFF: No conversion (depend on source), use Preamp/Volume function to output volume.
Apr 7, 2024 at 8:13 PM Post #894 of 915
With VOX regardless of input. Well, in theory...
A little way back, I learnt that there were iterations in VOX due to component shortage/availability. So it depends.
For example mine (Initial production) on its current FW, w/ DSD DIRECT ON, upsamples everything only to DSD256 and sends direct to output bypassing volume/preamp function. Since I upsample everything from HUB to PCM705/768 I usually set in VOX, DSD DIRECT to OFF (no DSD) and set volume/preamp control to MAX (no dithering).
Apr 8, 2024 at 7:42 AM Post #896 of 915
Ciao! In theory. If your input is the same to DSD256 / 512 (depending on FW).. Email. Nicolae to be sure...
Apr 8, 2024 at 1:07 PM Post #898 of 915
As input...
Apr 8, 2024 at 2:17 PM Post #900 of 915
Is it not the display on Vox shows the input data information not output?
So if it really converts to DSD we don't know exactly what it is... Since all outputs are analog. Noway to confirm if it is DSD or any other..
