Amarphael
- Mar 18, 2007
The wings are of the newer, wider design. They hardly play a role in the fit, Unless you have a head the size of a bear or a pigeon's.
Much more imprtant is that the pads should be thicker than the and more evenly shaped than W5K's are curved and somewhat lean. And the biggest concern may be the plastic headbands that are not possible to bend as the metal ones... a clear setback IMO.
