yes and it works perfectly
Audio Grade Fuses
- Thread starter BIG POPPA
Is the Purple Fuse the way to go in 2024 or is there an alternative for the same price
- Oct 11, 2012
I'm currently using the SR Purple in my mains cable feeding the PSM 156 but toying with the idea of swapping for an SR Master Fuse. Anyone using an SR Master Fuse in the mains cable supplying the PSM 156?In this position in the system is it a big upgrade, subtle upgrade or is the SR Purple better for the job?
carboncopy
Never heard about this solution before, but I found it to be intresting enough to try one. I can confirm the followings:Has anyone here tried the Swiss Digital Fuse Box yet? I'm waiting for the 240v version to come to market, don't want to risk buying anymore expensive fuses that blow for no good reason
https://verafiaudiollc.com/products/best-audio-products/swiss-digital-fuse-box-52299809
- the product is legit, it exists and works
- customer contact is excellent
- there is an EU Version, since I use one
The early impressions are really good, I cued up some songs I heard about a 1000 times and yep...there was even more to them. I will definitely buy more. And I am much more confident with this solution as with blow fuse which sometimes costs more as this eqiupment.
So, thanks for the info.
alvin sawdust
Thanks for the feedback, good info. Haven't got around to trying one myself yet but will do in the near future.Never heard about this solution before, but I found it to be intresting enough to try one. I can confirm the followings:
Which Sluggo are you using?
carboncopy
At the moment high purity copper. And I have a Supper Sluggo too here.Thanks for the feedback, good info. Haven't got around to trying one myself yet but will do in the near future.
alvin sawdust
Will be good to hear your thoughts.At the moment high purity copper. And I have a Supper Sluggo too here.
Doug2507
Been thinking exactly the same thing. Did you try the Master?I'm currently using the SR Purple in my mains cable feeding the PSM 156 but toying with the idea of swapping for an SR Master Fuse. Anyone using an SR Master Fuse in the mains cable supplying the PSM 156?In this position in the system is it a big upgrade, subtle upgrade or is the SR Purple better for the job?
Ghoostknight
unfortunaly not the blue one, just the white one so far https://de.aliexpress.com/item/1005004081348634.htmlHas any one tried the AUCHARM blue colored Gold Silver Nano Oil Immersion Fuse?
It seems to be the most expensive of the Aucharm fuses. I'd appreciate any comments from users or leads as to where I can get feedback on this fuse.
really good fuse for the price its hard to beat.... and it has beatin my AHP fuses i had before which cost 20-25 per fuse
What happens to the original fuse? do you replace it with a fuse that is just pure copper?Never heard about this solution before, but I found it to be intresting enough to try one. I can confirm the followings:
carboncopy
It will be replaced with the "Sluggo", which is a solid copper rod (for example). It is no "fuse".
IanB52
I wouldn't doubt that this sounds the best vs fuses. But, this one actually seems too risky for me. If that breaker fails at all, ever, for any reason...you, your gear, and home are in danger.Never heard about this solution before, but I found it to be intresting enough to try one. I can confirm the followings:
IanB52
Since I'm too risk averse for the Swiss Digital, I'm really curious how those Synergistic Pink fuses sound once people start using them.
