Looks perfect. Sonic density, musical.......... Exactly what I'm loooking for...One of these guys perhaps. Seems to fit the criteria.
https://highend-electronics.com/products/audio-magic-masterpiece-m-1-beeswax-fuse
Audio Grade Fuses
- Thread starter BIG POPPA
I can make you a fuse that's twice as sonically whet
Great. Is it mushy or fuzzy sounding? What is made out of?I can make you a fuse that's twice as sonically whet
Happy to be proved wrong but I read the comment as tongue in cheek.Great. Is it mushy or fuzzy sounding? What is made out of?
Thanks. I dont catch on th these things often times...Happy to be proved wrong but I read the comment as tongue in cheek.
I dont think it would be too mushy, more like damp topsoil than porridgeGreat. Is it mushy or fuzzy sounding? What is made out of?
I like you......I dont think it would be too mushy, more like damp topsoil than porridge
I have the following question. I have a PS that needs a 1A slow blow fuse. If I used a 6A slow blow fuse- would it affect the sound or only the protection?
I ask- because these fuses cost alot and if I switch components to something that needs more amps rating- I would not need to purchase a new fuse.
For me- I am already protected from surge as I have a superb balanced isolation transformer which protects all my equipment. So my only issue is would it affect the sound to use a much higher rated fuse when a lower rating is suggested.???
greenblured
Ime higher ratings for fuses in linear power supplies sounds better. What rating comes stock seems rather arbitrary imo. One 3A-5V came with a 0,5A, another 3A-5V came with a 2A fuse. If you dont't run the PS near max capasity and it's cool/ slightly warm too touch i belive it's safe to use higher ratings. Some even use sluggs instead of fuses. Personaly i use 2-3 times higher ratings than stock.I have the following question. I have a PS that needs a 1A slow blow fuse. If I used a 6A slow blow fuse- would it affect the sound or only the protection?
Has any one tried the AUCHARM blue colored Gold Silver Nano Oil Immersion Fuse?
It seems to be the most expensive of the Aucharm fuses. I'd appreciate any comments from users or leads as to where I can get feedback on this fuse.
https://www.aliexpress.com/item/100....order_list.order_list_main.23.5be51802bmSZmD
Has anyone tried 2,3, or more Master fuses in one system and what were the results?
Any pointer to good dealers in NA for SR Purple fuse would be appreciated
alvin sawdust
Blew my SR Purple fuse for no good reason, second time this has happened, the first being an orange a couple of years ago.
Thought I'd take the opportunity to pull it apart for your perusal. Apologies for the poor quality pics.
vvume
Thanks for sharing and sorry about the expensive loss. It is for this reason that I took a bit of risk and put in far higher amp rating AM M1 fuse in my dac, but a cheaper lower amp rated (3.15A) fuse further upstream (covering a lot more devices). So hopefully the cheap one upstream always blows first. Thankfully, nothing has blown so far.Blew my SR Purple fuse for no good reason, second time this has happened, the first being an orange a couple of years ago.
alvin sawdust
Has anyone here tried the Swiss Digital Fuse Box yet? I'm waiting for the 240v version to come to market, don't want to risk buying anymore expensive fuses that blow for no good reason
https://verafiaudiollc.com/products/best-audio-products/swiss-digital-fuse-box-52299809
