Maybe someone should create a di24 thread?
Audio-GD DI-20
- Thread starter soundlogic
FredA
- Dec 15, 2013
Yes. I will.
Tempted to buy oneMaybe someone should create a di24 thread?
FredA
- Dec 15, 2013
Agreed. Instead of $1000 on a second DI24, get a PSM156 power conditioner or a Topaz isolation transformer for the entire system- perhaps a bit more- but huge effect...
https://airlinktransformers.com/category/advanced-filter-power-supply
This should beat Topaz I was told by a friend. He says it does, but I have not owned an isolationtransformer.
Topaz model 31 and 32 have .0005 cpacatance- the lowest ever made to my knowlwdge. Not all Topaz models are that low- and this is the critical factor that makes the difference. In balanced mode it supposedly reduces noise by -165dcb (common mode noise).https://airlinktransformers.com/category/advanced-filter-power-supply
Here is the EMI filter that really intereste me to use in conjunction with my Topaz:
https://www.onfilter.com/ac-emi-filters-af-series
Has anyone succesfully used USB cables on the DI20/HE.
Without the power wires in the cable?
Meaning: only data is transferred
Interesting!Here is the EMI filter that really intereste me to use in conjunction with my Topaz:
So a powerstrip after this would be ok?
mivarpet
- May 22, 2015
Yep, I made my own USB cable with no 5V line and it works fine.Has anyone succesfully used USB cables on the DI20/HE.
ProLoL
- Jan 13, 2017
Yes, the DI20 accepted the usb without the 5v.Has anyone succesfully used USB cables on the DI20/HE.
Thanks!Yep, I made my own USB cable with no 5V line and it works fine.
Thanks!Yes, the DI20 accepted the usb without the 5v.
Yes. It works for me... But if you want the best usb cable in the world- at ANY cost just get: https://fibbrcable.com/products/alpha-usb-a-b-optical-fiber-digital-audio-cable. Every other USB cabe is a waste of time compared to this- it is so so much better...Has anyone succesfully used USB cables on the DI20/HE.
Nothing can beat it-- but you do need usb 3.0 output from your PC or streamer for it to work. Get a top of the line Power supply for it as well:
https://www.aliexpress.com/item/1005002287706260.html?spm=a2g0o.detail.0.0.7046BvRDBvRDsi&gps-id=pcDetailTopMoreOtherSeller&scm=1007.40000.327270.0&scm_id=1007.40000.327270.0&scm-url=1007.40000.327270.0&pvid=635a6f5d-9186-402c-91e9-f6304f038fd4&_t=gps-idcDetailTopMoreOtherSeller,scm-url:1007.40000.327270.0,pvid:635a6f5d-9186-402c-91e9-f6304f038fd4,tpp_buckets:668#2846#8112#1997&pdp_npi=4@dis!USD!144.00!144.00!!!144.00!144.00!@2140d3ff17044012760156211e0225!12000019922212039!rec!IL!732152500!
sajunky
It use custom USB chip, similar to Intona isolators and price was set to compete with Intona (and DI-20). Now they smell something, they reduced a price by a half.Yes. It works for me... But if you want the best usb cable in the world- at ANY cost just get: https://fibbrcable.com/products/alpha-usb-a-b-optical-fiber-digital-audio-cable. Every other USB cabe is a waste of time compared to this- it is so so much better...
It is not noise-free device as on the downstream side optical transmitters generate pulse load, therefore for a good effect it require the best PSU you can get... With an added cost.
Two years ago (maybe) I would go for it, but now there are isolator chips in serial production from Analogue Devices ADuM3165 and Texas Instruments ISOUSB211, market will be bombarded with USB dongles in the price range $40. No power required, like those (obsolete now for $9 max) on the screenshot from Aliexpress.
This I think, uses one of the next gen ADUM USB isolators you were referring, correct?It use custom USB chip, similar to Intona isolators and price was set to compete with Intona (and DI-20). Now they smell something, they reduced a price by a half.
https://www.aliexpress.com/item/1005006310871894.html
Total: 7 (members: 0, guests: 7)
