UNOE
Preliminary observations on Vesperaudio pads:
Best bass impact and amount..
Most neutral trebles..
Most neutral flat mids.
Soundstage a bit further away than both stock and Audio Technica pads.
A bit less lively in mids over Audio Technica pads.
Trebles placed a bit further away as well, in line with mids...
I believe these pads could be the best..
They certainly do look the best and also in quality and feel.
The slightly less lively presence in mids is easily attributed to the new pad thickness placing more ear distance from driver..
I have been spoiled by the Audio Technica pads being a bit softer and so collapsing more, placing ear closer to driver..
Vesperaudio pads are lush and full.
I decided to do the HM5 "pad crush" idea, to "break in" the pads overnight...
So we finally have a second solution that is just as good and more of another choice.
It does do what no other pad has addressed fully, which is treble tonality.
Which Vesperaudio pad? There is 3 different versions I think.
Leather+alcantara 2 cm thick(most popular thickness) with"fast foam", not "memory foam"...
This was the least customized version.
They can make practically anything you want.
I decided against angled pads for portability .
Inner dimensions are not as wide as the Audio Technica, which are a bit wider than optimal.
They are instead more deeper.
I have broken them in by compressing them about 48hrs,
So will do more comparisons today..
Currently I'm using M1 pads. I like the sound well enough just not all that comfortable yet more comfortable than stock. Which pad would you recommend for me. I found that m1 took a little of the punch away and that is good with me in fact I think I rather have even more punch taken out. I want bass though. Do any of the pads retain the bass but mininmize the punch while staying comfortable that you have tried?
