brasewel
I like the treble just the way it is, especially after coming from the Denons.
Very close the same in reality. In an extreme near-field and enclosed environment, I suspect there's not a significant sonic difference. That's what I observe with my two pair, old and new..
Same here. However, that FR graph still has a gradual shelf of almost 10dB between 1 and 3 kHz, and nowhere is the treble higher than the 1
KHz level. Not rolled off, but far from hot in the treble.
I agree, they're not too much different. My experience is that it's not the geometry, but the seal and amount of absorption/reflectivity the pads have that an change things up considerably.
I don't hear my new one as "hot" or "rolled off." I hear it as damn near perfect.
Kinda measures that way too. Measurements will be up soon.
One of the things I've been wanting to do is make a little gray swath in the background of the graphs that roughly indicates what flat is ... but I've never really had a headphone that I think nailed it well enough to know where to draw the lines.
I just might now.
Even better, IMO, would be to "zero out" the graph using the LCD-2 as flat. ..... Mr Green could zero it out using the ER4s, and see how headphones deviate from what he perceives to be flat. Others could use the LCD-2. Maybe the HD800 or HE6 could be another.
Just something I was thinking about. The software to make that happen might be kind of tricky.
How about putting the new pads on the old pair and check?
Tyll - can you listen to a good recording of violin music or brass instrument music on the LCD-2 and another pair of high-end headphones such as the HE-6, HD800, T1, or SR-007 and compare the detail resolution?
Whenever I read praise here for the LCD-2, I try them again to see if I missed something last time, and I just don't get the detail on acoustic classical music that I get with other headphones as well as speakers. I don't know if it's the shelved treble or something else, but it's a very obvious deficiency based on my listening.
I heard just that until I got the new ones.
Does anyone know when the pads changed?
It might, certainly.
Here's some pix:
