madwolfa
LCD2 was 500 grams pre fazor.
My Bamboo LCD-2 Fazor are exactly 526 gram.
This sounds more accurate. Website mistake probably.
LCD2 has much more upper midrange than the HE-400. The two aren't too dissimilar in the bass and lower midrange. The Audeze is thicker/smoother/more congested whereas the HE-400 is thinner/more textured/rougher sounding.
I actually don't consider the LCD2 to be that much better than the HE-400 if you EQ the HE-400's obvious colorations away. The LCD2 I heard was pre-fazor though, so fazor'd LCD2 might put it a little higher in sound quality. Comfort will be even worse with the fazor though.
That's a borderline fanboyish comment. People love to hate on the HE-400 in general, but its bass is one of the best in the business.
Well, to be honest, I've tried couple orthodynamics on our last meet, and found all their bass almost equally good (few HE models, LCD-2/LCD-3 and some Fostex T50)..
The only problem I have with it is I can never get the two pads to feel the same around my ears, and it makes me OCD so I keep fidgeting them around. That's only because they're old and the pads are uneven. Also I'm not perfectly symmetrical. Bending them out so there's less clamping pressure helps, or keeping my glasses on so the pads stick to me less.
Thought I was the only one. I was auditioning a buddy's old pair and bought LCD-3 pads because I didn't want to mix skin oils lol. Anyway, after long use, I'm not surprised when I see one pad in a completely different position than the other pad, after all the finger fidgeting. And somehow, the fit feels fine like this. I stop fidgeting when they're in odd positions than when they're symmetrical.
LCD2 was 500 grams pre fazor. It's 600grams now with fazor. The fazors are essentially an additional two metal plates on either side of the driver that include the triangular diffusers (which also touch your ear if your ears protrude enough.)
With or without the cable?
